Alternator 2.5 Td Ducato Base (1999)
Discussion in 'Motorhome Chat' started by bhs, Apr 25, 2015.
  1. bhs
    bhs Read Only Funster
    Apr 16, 2015
    214
    137
    Louth
    Had this idea that I might take a few spares on our forthcoming adventure, including an alternator, have heard reference to a high output alternator, anyone know out of these? the ones I am seeing are 110 amp which I guess is standard?
    Was also thinking of taking my towbar off for the duration of our trip, to reduce weight, is this worthwhile? Even considered leaving the other half at home so paranoid about payloads
    • Like it Like it x 1
  2. daveandsan
    daveandsan Funster
    Dec 10, 2013
    1,428
    2,010
    South Staffs
    That's a good idea.;)
  3. Tootles
    Tootles Funster
    Sep 14, 2013
    9,322
    33,516
    Lancaster
    I would suggest that unless you have added a large amount of direct electrical equipment to your vehicle, far above that fitted by the manufacturer, and involving a heavy draw on your battery(s) whilst the engine is running, then forget it. Your original alternator is quite adequate. (y)(y)
  4. rapido convert
    rapido convert
    Feb 26, 2015
    58
    113
    knutsford cheshire
    Hi bhs,
    The weight of the towbar will be around 60kgs if you have a fiat chassis and a large overhang, the spare alternator will weigh another 7kgs, i would suggest taking a spare diode which are readily availiable from maplins and a set of brushes which are availiable on line, this is what usually goes wrong with an alternator and only costs a couple of quid and weighs a few gramms.
    Weight aboard the motorhome is more about common sense than extras fitted, do you really need all thouse tins of food they really do have shops abroad.
    If you get a puncture are you going to change it yourself ?, if not leave the trolly jack and tools behind, travel with 5 litres of water for a cuppa, i have only travelled this way for many many years we only wild camp or use aires we have yet to draw a blank finding water when arriving near to our destination (i usually put €10·00 of diesel in the tank and fill the water from the garages tap).
    I could go on and on, but to find a starting point for what you can take get your bus over a weigh bridge.
    Andy.
