alloys for the van
Discussion in 'Fiat' started by Munchie, May 28, 2010.
  1. Munchie
    Munchie Funster Life Member
    Jul 28, 2007
    8,579
    11,800
    Champagnac-La-Riviere
    Thinking of getting alloys put on the van. Any advice or opinions please?:BigGrin:
  2. bluelass
    bluelass Read Only Funster
    Nov 30, 2009
    16
    north wales
    I've just bought some for my van conversion. Must say they look rather snazzy. I was parked next to a Trigano Tribute last weekend and from a distance the vans look pretty much the same....but those alloys really did look good!
    Some would say 'keep your money in your wallet' and it depends what else you need to get before the alloys. Mine is an oldish Youngs conversion that's in need of a few internal upgrades too but I'm leaving those until after the autumn when I'll be using the van much less.
    Hope this helps.:thumb:
  3. greygit
    greygit Read Only Funster
    Aug 11, 2009
    274
    232
    Forest of Dean, Glos, France and Spain
    We haven't got um on ours but I would like some as "in theory" they are lighter than steel ones so they shouldn't transmit so much road surface vibration through to the vehicle.........at least that's what we were told at Tech Collage many moons ago as very young apprentice mechanics.
    Greygit:Smile:
  4. cater_racer
    cater_racer Read Only Funster
    Oct 15, 2008
    46
    Chester
    Waste of money, the steel one flex a bit and THEY reduce road vibration. Lighter unsprung weight would improve handling and fuel consumption, but you won't notice either.
    The pickeys will try to nick them, so you'll need locking wheel nuts. If you kerb them you'll hate yourself, and they will constantly need cleaning.
    I've gone for nice wheel trims, tied on with tie-wraps.
    Spend the money on a ferry ticket and some diesel.:Smile:
  5. cater_racer
    Oct 15, 2008
    46
    Chester
    Waste of money, the steel ones flex a bit and THEY reduce road vibration. Lighter unsprung weight would improve handling and fuel consumption, but you won't notice either.
  6. Pugboxter
    Pugboxter
    Oct 13, 2008
    59
    Alloy wheels are also nearly always heavier than steel wheels, and I'd imagine alloy wheels marketed for a van will definitely be heavier than the standard wheels....... however having said that if you want some alloys get some.
    I have some alloys on my car that are 1.5kg heavier per wheel than the original steel wheels, but I like the way they look.
  7. WillH
    WillH Funster
    Feb 9, 2008
    1,724
    1,436
    SW Scotland
    They are only useful on a road vehicle if you are really racing. Using alloys reduces the unsprung weight and allows the tyre to be in full contact with the road longer when travelling over bumpy surfaces as the suspension will return the wheel to the road faster. Given the overall weight of the van compared to the wheels any gain in comsumption and handling will be undetectable and at ordinary road speeds they make no difference. Performance is only enhanced at speeds well above the limit.
    However, if they look good, fit them.:Smile:
    Bill
  8. wanttobeaway
    wanttobeaway Read Only Funster
    Oct 26, 2009
    55
    on tour
    If you like the look of them get them as you will be thinking about them all the time now and they do look good
  9. lebesset
    lebesset Read Only Funster
    May 31, 2009
    760
    have been down that path , but it was a bad idea because a motorhome tends to spend more time on grass and gravel etc than a car
    suffice it to say that they soon started getting marked , and refurbishment is expensive !
    so my advice is ...don't bother
    btw , if you do decide to do it , be very careful , a lot of wheels that appear to fit are not designed to carry the weight , they are for cars
    the clincher for me was that , as someone has said , they turned out to be heavier ...for some reason I thought they would be lighter
  10. Mick H
    Mick H Read Only Funster
    Oct 13, 2007
    40
    Near Leicester
    Our motorhome came with alloys as standard. They ARE lighter than the steel ones, because I weighed one against the steel spare.
    Alloys still look good after a few years of use, wereas steel ones often show their age with rusting, but I found that alloys need removing every year,and a good coat of grease or similar applied to the mating surface, to prevent them becoming corroded to the hubs.
    Having never had alloys before, I didn't choose them, but definately would in future.
  11. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,154
    13,980
    Heavan
    go get em poser
    I got nothing but stick from those on here when I asked the same question. I love em, look great and worth it IMO, but to me Im an image freak!!! Had some on my last van that I bought and they looked ace. I was going to put them on to my new van but they were 15" and mine is 16". despite what the gloomers will say, you can get decent quality ones that wont collapse,
  12. Munchie
    Jul 28, 2007
    8,579
    11,800
    Never gave collapsing a thought :Eeek:
    Reason we are thinking of them is that the steel wheels are starting to look scruffy And I was led to believe they are lighter? :RollEyes:
    I think my wheels are 15" and I have seen some Wolfrace ones at £250 for the 5 on the web. Am I looking too cheap? :Blush:
  13. scotjimland
    Jul 25, 2007
    28,934
    25,603
    if you access to Facts do a search, there was a post by Pjay about one of his ally wheels collapsing .. worth a read and some good pictures .. scary stuff :Eek!:
  14. Robinhood
    Robinhood Read Only Funster
    Mar 7, 2010
    159
    Sherwood Forest
    You definitely need to get heavy-duty ones that are specifically designed for commercial vehicles (and also for your particular base vehicle so that the PCD and offset are correct).
    http://www.tyresave.co.uk/alloyvan.html will give you some ideas.
  15. Forestboy
    Forestboy Funster Life Member
    Jul 31, 2007
    5,086
    8,178
    Forest of Dean
    Don't listen to the Doom & Gloom merchants:Eeek:
    If you want them and they make you happy you get em mate :thumb: its your money spend it how you like.:thumb:
    Saw a van recently with a set of alloys on it looked fab:BigGrin:
  16. Munchie
    Jul 28, 2007
    8,579
    11,800
    Yep thanks, wheels on front page are the type we were thinking of. Price is not outside our remit neither.:thumb:
  17. Wintonian
    Wintonian Read Only Funster
    Nov 30, 2009
    122
    Brittany, France
    I don't know about alloy car wheels, but we have a Ducati 996 SPS (a rather special motorbike for those that don't know) which is fitted with very strong forged (not cast) magnesium alloy wheels made by OZ. They cost about £2,000 for the pair. They are designed and built to take the extreme forces experienced on the race track. The standard cast alloy wheels fitted to most road bikes cost a great deal less than that, but would not be trusted for the forces experienced on the track. The same applies to car wheels. The alloy wheels tend to be machined castings, whereas F1 wheels, for example, are forged for greater strength and lightness.
    Motor Homes subject their wheels to very high loadings an, I would have thought, would have to be originally fitted with wheels that have been designed to take those forces. A manufacturer that offers alloy wheels as an option will have determined that. Ask the manufacturer what the price of the OE wheels would be and compare that with prices that you see on eBay etc. You may be surprised!
  18. robnchris
    robnchris Funster
    Jan 11, 2010
    1,350
    1,670
    Chester
    alloys
    Hi,
    For us it`s all about your motorhome and putting your stamp on it, why not personalise it a little and make it stand out.:thumb:
    Go for it it`s your pride and joy make it special, if we only spent our cash on the necessities of life what a dull place it would be...
  19. Supertractorman
    Supertractorman Read Only Funster
    Sep 7, 2007
    415
    3
    I have alloy wheels that were supplied with the van new. Only disappointment is with the chromed wheel studs going rusty I guess due to torque wrenches not being a good fit when tightening the wheels. Anybody know any firms who will re-chrome studs at sensible money ?.
  20. Wintonian
    Nov 30, 2009
    122
    Brittany, France
    Have a look in your Yellow Pages. In my experience there are many plating firms all over the place who will do small jobs and don't charge very much. I have had small aluminium alloy parts anodised, too.
