Alloy wheels
Discussion in 'Motorhome Chat' started by albial, Nov 26, 2015.
  1. albial
    albial Funster
    Dec 9, 2013
    41
    16
    Derbyshire
    My motor home has alloy wheels, my spare has steel. In the event of a puncture and I had to use the spare could the wheel nuts from the alloy wheels be used. Thanks for any input.
  2. icantremember
    icantremember Funster
    Sep 2, 2010
    5,387
    7,490
    Nr Watton in Norfolk
    We have a Peugeot X250 based m/h and yes we use the same wheel nuts but this may not be so for all base vehicles.
  3. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,509
    2,734
    Surrey
    I think you are supposed to use the spare as exactly that, ie get a puncture, put steel on, and then repair the alloy one and re-fit it. A bit like a space saver, only the correct size.
  4. Violet1
    Violet1
    Jul 4, 2015
    84
    86
    March, Cambs
    As above poster, tyre will be correct size etc wheel nuts will fit but change back to alloy as soon as poss. And keep spare as spare, had same thing on skoda
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,088
    17,759
    YO11 2BD
    Alloy and steel wheel nuts/studs always USED to have different seat tapers.
    Times may have changed.
    • Like it Like it x 2
  6. Mikeco
    Mikeco Funster
    Sep 26, 2013
    732
    543
    Market Rasen
    Do not assume that the wheel bolts from the Alloy wheels can be used for the steel spare. On a Fiat based Burster we had the ones used for the Alloy wheels were too long for the steel spare as I found out in Germany. I had to buy different ones to allow the spare to be used.
    • Like it Like it x 1
  7. pappajohn
    Aug 26, 2007
    30,088
    17,759
    YO11 2BD
    One thing be aware of if you have 'blind' locking nuts.
    When using the steel spare wheel the nuts may tighten onto the end of the thread before tightening onto the wheel.
    I pushed the end off one locking nut while torqueing a steel space saver because it tighten to the stud before the wheel.
  8. matamoros
    matamoros Funster
    May 15, 2008
    2,503
    3,958
    Rochdale, Tavira, S. Brittany & Europe
    On our hymer caravan the wheel studs are different lengths, different profiles and different hex socket size. Is there nothing in the manual, I would think the results could be catastrophic if the wrong studs/nuts are used.
  9. albial
    albial Funster
    Dec 9, 2013
    41
    16
    Derbyshire
    Hi thanks for your reply. My motor home is on a ford base so I will play safe and get wheel nuts for the spare.
    Thanks. Albial
  10. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,676
    23,047
    Narrfoook
    Ducato X250
    Ally's fitted, steel spare, nuts the same :)
    ( Dont ask how I know .. DOH !!!!!!!!!!! )
  11. GWAYGWAY
    GWAYGWAY Funster
    Sep 6, 2014
    2,184
    1,582
    Dover
    My Fiesta Car has alloys and a steel spare there is a special collared wheel nut on the alloys and ordinary tapered nuts for the steel one the hole in the allow much bigger than the other one. Have a close look and check the manual carefully.
  12. Brian and Jo
    Brian and Jo Funster Life Member
    Sep 24, 2007
    2,218
    4,368
    oswestry,shropshire
    as long as they are factory fitted wheels and the spare was supplied by the factory they will be fine.I have alloys on our N+B and a steel spare and the same wheel studs do both.
    Brian & Jo
  13. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,730
    3,377
    Cumbria
    The wheel nuts on my alloys fit the steel spare, however, the supplied Renault toolkit didn't fit the wheel nuts ! Drove around for three years before I tried the supplied tool kit and jack out on the drive. I now carry a breaker bar, socket and 4 ton hydraulic jack with me. Think I had a lucky escape, suggest you have a try out on your drive too for peace of mind (y)
  14. albial
    albial Funster
    Dec 9, 2013
    41
    16
    Derbyshire
    Hi All
    It is a hymer factory fitted alloys checked today and it looks as though they will be ok. Thanks for your input.
    Albial
  15. TerryL
    TerryL Funster
    Mar 5, 2010
    1,423
    1,408
    North East
    Just to add a little warning - I fitted after-market alloys but kept the steel spare. The alloys wheel nuts were quite different to the steel, so I kept a set of wheel nuts for the spare.
  16. PeteH
    PeteH Funster
    Nov 22, 2007
    2,213
    2,756
    East Yorkshire
    Some years back I Had a Company Supplied, Astra, with Alloys and a Steel Spare. The steel spare had ITS OWN studs. and a warning NOT to use the studs from the alloy wheels. When I queried it with the Dealer. I was told the the Taper under the head of the Stud, was a Different Angle on the alloys, as to the steel, and it was likely that in use with the "Wrong" Studs would work loose, It also had different Torque Settings BTW.
    Guess it is worth checking on?
    Pete
