Alloy wheels
Discussion in 'Motorhome Chat' started by octopush, Jan 25, 2015.
  1. octopush
    octopush Read Only Funster
    Sep 28, 2012
    133
    51
    portsmouth
    I have a peugeot boxer 2004 autocruiser starblazer G and would like to fit some alloy wheels to it.
    Can anyone tell me what wheels will fit.
    Is it a case of finding some the same size or do they need to be specific wheels for the weight of the van.
    Thanks Rob
    • Like Like x 1
  2. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,574
    9,999
    there are both OEM and after market wheels available but they do have to be commercial vehicle grade and rated correctly to carry the heavy weight. there's been a few sets offered on ebay recently, but even second hand, they're not cheap.
  3. Mikey RV
    Mikey RV Funster
    Mar 7, 2010
    1,111
    3,171
    Devon
    They have to be load rated. Don't be tempted to just put any wheel on.
  4. Chockswahay
    Chockswahay Read Only Funster
    May 29, 2012
    3,097
    4,796
    Just a thought, alloy wheels look sexy but they are very expensive to buy and maintain. Good old fashioned steel wheels are cheap and very tolerant to knocks and bangs, it is easy to knock out any dents etc. If you want sexy there are some quite nice wheel covers out there?
  5. scotjimland
    Jul 25, 2007
    28,934
    25,603
    In addition to the last post.. very attractive to thieves..
    stick with the big ugly tough steel wheels.. (y)
    I've also read, don't know if true or not, that unless you buy high performance expensive alloys, they can be heavier than the steel counterparts..
    • Like Like x 1
  6. GWAYGWAY
    GWAYGWAY Funster
    Sep 6, 2014
    2,077
    1,468
    Dover
    WHY? They look flash!!! They dent like mad!!! They cost a bomb to buy!!!! They corrode with salt!! They need a complete set of special wheel nuts/bolts. They are heavy as hell for the needed strength to equal steel ones.!!
    I have had to replace two alloy wheels on my Fiesta at£117 + each following a pothole incursion that also cost two tyres.
    • Like Like x 2
  7. Jonkil
    Jonkil
    Dec 27, 2014
    963
    3,174
    Ireland / London
    I have alloys on mine, on it when I bought it.
    Now corroding and lacquer peeling.
    About to refurbish them, I will post before and after pics.
    • Like Like x 1
  8. Nirvanauk
    Nirvanauk Funster
    May 8, 2011
    1,404
    7,421
    God's county. North Yorkshire.
    I wish my van had steel wheels, like the above post the lacquer has peeled and they look naff. Also, they leak and I have to pump them up before any trip. So steel wheels for me from now on.
    • Like Like x 1
  9. motorhomer
    motorhomer Read Only Funster
    May 17, 2008
    578
    317
    South Shropshire
    Alloys look nice. In THEORY they are lighter, and therefore reduce unsprung weight which should help the ride and roadholding.
    In practice I doubt anyone would notice any difference. And they have lots of drawbacks. My van and car have alloys but I would never through choice pay more to get them.
    • Like Like x 1
  10. octopush
    Sep 28, 2012
    133
    51
    portsmouth
    Thanks for the advice.
    I am going to stick with my steel wheels now.
    • Like Like x 2
  11. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,692
    3,275
    Cumbria
    Ours has alloys on it from when we got her, as said by others, lacquer peeling off now and the first time I took one off the van, it had seized onto the iron hub with that powdery white corrosion, had to go round and take the other 3 off whilst it was on the drive and copper slip the hubs. Having said all that, the underslung steel spare was in a terrible state and wasn't air tight so I had to get that blasted and powder coated. As had been mentioned earlier, you might need to change the wheel nut sizes, never considered it with mine till I tried to remove one with the supplied wheel wrench, which didn't fit, pleased it wasn't a puncture away from home.
    Next job is to take all 4 wheels off and get them powder coated but when's a good time as I use the van as my daily transport :(
    On the plus side, they do look nice and are slightly lighter.
  12. GWAYGWAY
    GWAYGWAY Funster
    Sep 6, 2014
    2,077
    1,468
    Dover
    I also forgot to mention that the side walls corrode causing slow punctures where the bead is disturbed.
  13. octopush
    Sep 28, 2012
    133
    51
    portsmouth
    Yep have that problem with my car alloys
  14. Jonkil
    Jonkil
    Dec 27, 2014
    963
    3,174
    Ireland / London
    Removed mine today, MH now sat on axle stands.
    Will sandblast them, coat of etch primer, 2 coats silver and clear coat of lacquer.
    Makes them look like new again.
    • Like Like x 2
  15. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,620
    2,191
    Rutland
    I had steel wheels on mine that were rusting and looked awful.
    I thought about buying alloys ,but as others have said , they cost a lot and when you come to sell your van they won't really add to the value.
    Mines fiat based and I bought a set of wheel trims that were fixed to the van by the wheel nuts .They look great can't be nicked without taking the wheel off ,and won't fall off on the way to wherever .
    I think the set of four cost £80 ish off ebay and the van looks so much better for little outlay.
    Vlad
    • Like Like x 2
  16. FJmike
    FJmike Funster
    Jul 17, 2014
    785
    849
    Swindon
  17. Chockswahay
    May 29, 2012
    3,097
    4,796
    I have a genuine question..... other than vanity what is the actual point of alloy wheels?
    • Like Like x 1
  18. Borderland
    Borderland Funster
    Nov 5, 2014
    433
    2,473
    Borders
    Had the same problem so took them to a local alloy wheel restorer, cost was £40 for all 4 wheels but saved the weekly chore of having to pump them up.
  19. Borderland
    Borderland Funster
    Nov 5, 2014
    433
    2,473
    Borders
    I think we all like our vehicles to look nice and alloys add to the appearance.
    • Like Like x 1
  20. Scout
    Scout Funster
    Apr 4, 2009
    3,299
    8,755
    doncaster
    Ive got alloys, in fact four sets, one the m/h which is coming up to 10 years old, they are almost as good as new, no chips dents or peeling, they have never stuck, my 10 year old nissan has them they are good too, as are the orgianal fitted ones on the cmax with summer tyres on, the after market ones with winter tyres on ( still in garge as did not put the mon this year) they were ok last time I saw them.
    Alloys I love emm, steel wheels paaa:moon2::moon2::moon2::moon2::moon2::moon2::moon2:
