Alloy Wheels, steel spare- do I need different wheel bolts? (2 Viewers)
gerry mcg
1,650
2,571
Glasgow, Scotland
Globecar 600L Revn
since 2016
My van has 16" fiat alloy wheels. I checked the spare and it is a steel wheel.
I recall reading something to the effect that the alloy bolts are a different length (longer) than the steel wheel bolts and it is not advisable to use alloy bolt if fitting a steel wheel.
Can anyone confirm / deny this?
Sep 25, 2009
793
1,386
south yorkshire
coachbuilt
since 2004. Tugger 10 years on and off
I don't know for sure but I know most cars mine included has alloys.but a steel spare and the same bolts are used.I once asked a rac guy the same questions and he gave me the same answer.
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
We had alloy wheels on our Autosleeper and a steel spare. We also had a separate set of 5 wheel nuts, I assume for the steel wheel but no instructions how to use them. Luckily, we never needed to. It might be an idea to either contact your manufacturer or visit a wheel and tyre specialist and ask them for advice.
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Camping Caravaning now 5'ering 49 years
Generally it is fair to say it is safe to use bolts or nuts for Alloys on steel wheels but NOT the other way around. This is due to the added length of the stud or bolt to suit the thickness of the alloy wheel. Having said that I would say contact Fiat to check and generally if separate fixings are required they would be supplied as part of the spare wheel/ jack/ breakdown kit combination.
Lenny HB
53,321
149,521
On the coast in West Sussex
Hymer B678 DL
Most cars the Collar angle is different on bolts for alloys but I believe they are the same on the Ducato, only difference being bolts for alloys are a couple of mm longer.
@Techno should be able to confirm.
2657
That would also be my advice, some do need separate bolts and some don't.
As well as different lengths they can also have different bevel profiles.
Nov 13, 2012
440
438
Somerset
coachbuilt
since 2000
I asked this question when I picked up new van which has alloy wheels and steel spare and was told if alloys are factory fitted then bolts are correct for steel spare, but if not factory fitted may need 2 sets of bolts as the cup profile may be different.
jtp890
591
393
wakefield
Dethleffs 7014
13 years on n off
We came across this on a Peugeot 108, spare wheel steel , when fitted bolts for alloys fouled brake inards and locked wheel up. Carried some steel spacers as temporary low speed fix. Need to check mine on Renault Master.
