Alloy Wheel load bearing? ?
Discussion in 'Tech/Mech General' started by wiljoy, Oct 16, 2016.
  1. wiljoy
    wiljoy Funster
    May 23, 2008
    918
    998
    Crook, Durham
    Help again please. .
    I'm considering fitting a set of alloy wheels to my 4.25t motor home. The last time I had dealings with alloys was in the 90's and they were fitted as standard. After 3 months they started to crack and it was found they weren't suitable for the vehicle size. I've found a set and each one is stress tested to cope with 940kg.
    Can anyone advise me if this load tolerance would be acceptable on my vehicle.
    Many thanks in anticipation
    Wilf
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,220
    15,203
    Leeds the one up North
    Can easy get alloys with 1250kg or even higher load rating. What vehicle chassis is it and wheel size? and year!
    EDIT 940 kg is not adequate
    • Like it Like it x 1
  3. DuxDeluxe
    DuxDeluxe Funster Life Member
    Jul 10, 2008
    9,462
    25,469
    Planet Zog
    Probably not.....don't know which vehicle, but ours has 2240kg max at the back axle, so you would need alloys rated at least 1120kg. I looked into the business of fitting alloys but in motorhomes there is nothing to gain apart from looks as they weigh about the same as steel wheels.
    Edit - as per Andy above
  4. Derbyshire wanderer
    Derbyshire wanderer Funster Life Member
    Mar 30, 2014
    567
    921
    Derbyshire
    I think you have answered your own question as 4 of these alloys will still be 490kg short of what is required unless it's a tag axle.
    Also although not important to some, your insurer would see it as a modification (and if aware of the loading data would not cover them)
  5. Techno
    Jul 28, 2010
    14,220
    15,203
    They need to at least match the tyre load index
  6. DuxDeluxe
    Jul 10, 2008
    9,462
    25,469
    Planet Zog
    Yes, usually equal to or in excess of the rear axle max load. We are looking at the issue from two different directions, which is nicely constructive... (y)
    • Funny Funny x 1
  7. Techno
    Jul 28, 2010
    14,220
    15,203
  8. wiljoy
    wiljoy Funster
    May 23, 2008
    918
    998
    Crook, Durham
    Sorry for not giving all the facts.
    It's on a Fiat with Alko chassis and has 16"wheels. Model is a carthago AClass .
    Many thanks for all your advice to date.
  9. TerryL
    TerryL Funster Life Member
    Mar 5, 2010
    1,459
    1,430
    North East
    http://www.tyresave.co.uk/alloyvan.html specialise in alloy wheels for motorhomes. Big range and very helpful over the phone to make sure that you get suitable wheels. Be aware you may need different wheelbolts too - Tyresave can advise and of course sell you a set.
