Alde water heater. (1 Viewer)
Sausage44
39
8
Bicester
Low profile
New at it!
Away at the moment at the moment and having to use gas for everything. When on electric all was ok but this is the first time I'vehad to use gas. I keep getting gas error on the control panel. Read the instructions but not much help. Only hot water needed. Any thoughts anyone?
Trout bum
567
584
Ayr
Adria Matrix M670SL
Hi is anything working on gas is cooker , if not and gas is on you might have a crash safety type regulator , where the hose goes into the gas bottle there should be a green button , turn gas bottle on and press this green button in then at the regulator end there will be another green button press this in also , that will allow the gas to flow to appliances , good luck
funflair
19,346
30,232
Guisborough
MORELO palace
since 2012
Hopefully its all working now as it was a Month ago that Sausage had the problem.
Martin
S
Sausage44
39
8
Bicester
Low profile
New at it!
Thanks for the replies, problem is still there - waiting for the dealer to book it in. Tried resetting both green buttons to no avail. Gas is getting through but very low pressure.
Sounds like a faulty valve. Been away a few times since but always on electric.
flatpackchicken
1,277
1,757
BICESTER OXFORDSHIRE
A Class Frankia I8000
Since nov 2009
Sounds very much like the regulator
Try turning on 1 gas hob on full and if it lights ok then reduces down to a very low flame then may well be regulator.
Good luck
Regards Garry Flatpackchicken
