Alde Heating.
Discussion in 'Tech/Mech General' started by Snowbird, May 25, 2014.
  1. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,286
    16,959
    Liverpool.
    The new van has the Alde heating system and from the little I know its worked from the engine electric and gas. There seems to be pipes everywhere including underfloor. I had it running on gas yesterday and although it got the van hot in a short time, I noticed that after about an hour the red light came on by the gas igniter. Is this normal and is just telling me that its up to temp or is there something wrong. Should I have any concerns regarding all those joints possibly leaking. I do quite like the idea of arriving at destination with hot water from the engine calorifier. Although the new van is made by the same people as the old van, its a completely different animal and everything seems quite high tech to an old codger like me.
  2. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,914
    39,983
    Dear Old Codger...
    We have the Alde heating system, and it`s great..
    Got a switch on the dash board that if turned on heats the radiators from the engine..
    Also runs of Gas or 1 - 2 - 3 kw on mains or through the inverter, inverter struggles on 2 to 3 kw..
    Bit thirsty on gas,,,, I think... :Sad:
    Other than that cant help it`s all controlled from a computer.. (More to go wrong.:Sad:)
    Not had any problems with all the joints... dont think it is a huge presure through the pipes..
    :thumb:
    • Like it Like it x 3
  3. alfandM
    alfandM Funster
    Mar 12, 2012
    1,044
    1,075
    sweden
    HI Dave,we have it seems exactly the same system in our old girl, for a start very reliable heating system,and like yours it has a change over system from engine heating through to the aldi heating in the living area, always toasty on winter travels,it run,s on ever Gas,12v electric or mains electric,so where ever you are you got warmth,when ours is running on 12volt the red light always come on after awhile but never on mains or gas,ive checked with the book and that seems to be normal,some with to with circulations pump,and for the clips they re great,never had a leak at all in the years we have had her,the clips are designed to expand and extract as temps change,all in all a great system, hope you and the other half enjoy ya travels in ya New Home,all the best Alf.
    • Like it Like it x 1
  4. icantremember
    icantremember Funster
    Sep 2, 2010
    5,395
    7,497
    Nr Watton in Norfolk
    We have the Alde heating system which has so far been very reliable and efficient. At first it was a little fiddly to set the clock and timer each time after running the engine but now I have fitted a battery back-up from the leisure battery this is no longer a problem as it keeps all it's settings.
    I haven't seen a "red" light on our system so can't help on that.
  5. dpsuk999
    dpsuk999 Funster
    Jun 6, 2012
    333
    296
    Leeds
    I too have the Alde system and it's fantastic. It has the heat exchanger under the bench seat too which as I understand when I switch it on and hear the pump start, if the engine is warm and running then it heats the MH radiators and hot water (have to have the system switched on and set the temp but turn off the gas and electric options so all that it's doing is circulating pump is on taking the heat from your engine coolant and transferring the heat through the heat exchanger), but also works the other way round in that if the MH radiators are hot then it warms the engine.
    Well that's how it was explained to me and appears to work that way lol but would love someone to confirm my understanding that I need to switch the pump on for it to work either way.
    Regards, David.
    • Like it Like it x 4
  6. Snowbird
    Apr 24, 2009
    10,286
    16,959
    Liverpool.
    I also have the tap with the heat exchanger under the dash. As far as I can gather there are two 12 volt pumps. One by the boiler for gas and mains and another on the dash for the engine heat. By the boiler there are 3 taps, lounge, bedroom and garage and underfloor. These can be used to direct heat to whatever part of the van needs it. On the control panel there are 2 settings for mains, 1KW and 2KW and 1 for gas. I have not tried the mains as yet as I have no lead, but the gas works OK apart from the light coming on after about an hour. If I switch it off and then on again it stays on, so wondered if this was normal and it was just recycling or if there was a fault.
  7. old-mo
    Oct 16, 2008
    12,914
    39,983
    As an after thought, Dave...
    Check your reservoir, make sure it is up to the mark, and only use what the book says...
    I think it is some sort of anti corrosion anti freeze.. :thumb:
  8. Snowbird
    Apr 24, 2009
    10,286
    16,959
    Liverpool.
    Just found the reservoir Mo, its up to the mark but as the instructions are all in German I have no idea what type of anti freeze you put in it. Is it just normal car anti freeze.
  9. Wyaye wires
    Wyaye wires
    Sep 13, 2009
    3,831
    9,284
    Berwickshire
    You can get the proper stuff off ebay or even at Halfords I believe...
    Google Alde anti-freeze...
    • Like it Like it x 2
  10. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,014
    13,870
    Bolsover, Derbyshire
    Useful thread thanks, I have Alde but did not realise it could run via the engine, we have a switch on the dash that I have randomly turned on and off thinking it was additional heating for rear, seems I was sort of right, but I did not realise the Alde controller needs to be turned on but gas and electric both turned off
    I normally leave the electric option on all the time, then as soon as we hook up it works, (depending on set temperature) the gas I turn on and off when not on hook up, so my 'norm' when driving would be elec on, gas off, so if I have read correctly above the engine will not run the Alde :Doh:
    So if when set correctly (elec and gas off) is the temperature then controlled by the Alde controller ?
    Thanks all, David
  11. old-mo
    Oct 16, 2008
    12,914
    39,983
    I`ll check the book, Dave.. and get back to you..:thumb:
    Not sure.. :Sad:
    Just noticed Wayaye wotsit answered your question... so I wont look... :Wink::BigGrin:
  12. Snowbird
    Apr 24, 2009
    10,286
    16,959
    Liverpool.
    Mine has a small tap by the heat exchanger. This I presume opens and allows the contents of the engine water to circulate through the Alde system when the 12 volt engine pump is switched on. By this I would also presume that the Alde system is full of the same stuff as the engine cooling system. In very cold weather it can be used the other way around to pre heat the engine from either gas or mains electric. Another presumption I must add.
  13. Wyaye wires
    Wyaye wires
    Sep 13, 2009
    3,831
    9,284
    Berwickshire
    [/HI]
    I think you are correct.
    I'll dig out my Alde booklet later and scan it in if you need one..
  14. alfandM
    alfandM Funster
    Mar 12, 2012
    1,044
    1,075
    sweden
    yes Dave i always top up with normal car antifreeze making sure the antifreeze is for aluminium, i use 60% mix for the cold conditions up here,going back to the circulations pump we have two one from the engine to the exchanger,and the other by the aldi system,both of 12v,so when on main electric and gas you will need the 12v system on,by the way Dave in the winter you can use the aldi system as a engine heater,there should be a valve by the exchanger that reverses the flow allowing to heat up the engine coolant,smart idea from aldi and a great product, :thumb:Alf.
  15. olley
    olley Funster
    Jul 29, 2007
    3,829
    2,381
    Ipswich
    Not had it or got it, but from a discussion on it on facts, the engine and Alde are separate systems. They use a heat exchanger to transfer the heat from one system to another. (Engine/Alde) See here: http://www.alde.co.uk/itemdetails.php?itemId=58
    Ian
  16. JJ
    JJ Funster
    May 1, 2008
    14,889
    26,701
    That van seems to be a bit too advanced for you Dave...
    As a mate I'll do you a favour and take it off your hands. :thumb:
    JJ :Cool:
  17. old-mo
    Oct 16, 2008
    12,914
    39,983
    "Olley"... Ian.. is correct they both have there own separate sealed water system`s... :thumb:
  18. Snowbird
    Apr 24, 2009
    10,286
    16,959
    Liverpool.
    Thats very civil of you my old friend. Will certainly beer that in mind when it all gets to much for me.
  19. Snowbird
    Apr 24, 2009
    10,286
    16,959
    Liverpool.
    Ahah, hence the heat exchanger. I completely forgot what a heat exchanger actually does. It keeps both systems separate.
  20. Deus Omnipotens
    Deus Omnipotens Read Only Funster
    May 25, 2014
    29
    24
    Scottish Borders
    According to my manual the red light serves 2 functions on my heating control panel.
    Red light flashes if the voltage to the boiler goes below 10.5V
    Fixed Light the LPG boiler has become blocked.
