Our heating is making gurgling sounds any suggestions? Could ot be water on the heating exhaust? It's still giving out heat.
John
John
I agree ..... but when cold the level should only just be above the bottom of the tank as it will expand when hot and overflow!I'd also check the fluid level in the expansion tank.
The correct antifreeze (VW G12+ or G13) is a long life antifreeze and should be changed every 3 to 5 years.The antifreeze mix should be changed regularly,
