I've just spent the day replacing the Alde engine pre heat pump which was leaking. On my last trip out I noticed the engine coolant had gone down quite a bit so topped it up and decided to check again a couple of weeks later and low and behold it was again down which indicated a leak somewhere but there was no coolant on the drive so decided to empty my lockers out.
For information this pump is used to circulate the engine coolant round a heat exchanger/engine which in turn is linked to the Alde heating so either when you have the Alde heating on (whilst on site) you can heat the engine coolant before starting your journey (I think it's for when you are for example skiing and want the engine warm before setting off) or alternatively when you are driving the hot engine coolant is circulated round the heat exchanger to heat the Alde heating and also the hot water so when you arrive on site your van is toasty and hot water on tap.
Anyway after emptying one of the lockers (where the pump is located it was wet and it's where I store the safari room bags which were all wet and stained red from the red coolant. When I inspected the pump closely i could see a small drip coming from where the body is screwed to the head!
So onto Alde website and I was amazed that the cost of a new pump was £240!! Anyway after some research I found that the pump is actually a Johnson pump so after googling I found a marine company up in Glasgow who had the very same pump (without the Alde badge) for £98.25 plus vat!
These guys were amazing and shipped very fast!
I also bought 2m length of heater hose, 16mm internal diameter to replace the hose.
Instead of having to drain all the engine coolant I used pipe clamps which are commonly used to clamp rubber pipes for fuel or coolant etc which saves a load of time.
Here you can see I clamped off the pipe which goes from the heat exchanger to the pump
I then went under the van and clamped the other coolant hose (ignore the join and jubilee clips as I took the picture after fitting the new pump)
which went to the other side of the pump and cut the hose. The only coolant lost was between the top clamp through the pipe/pump and the outlet on the pump to where I cut it under the van.
I then removed the old pump and pipes from the circuit
and attached new pipes to the new pump
I then reinserted them through the floors, one going above to the heat exchanger and the other through the van floor to re join the circuit
New pump in place
Interestingly the instructions for the pump had in BOLD that if the pump was installed horizontal then the outlet pipe should be pointing upwards to stop air locks and guess what.....the old pump was installed horizontally but with the outlet pipe going downwards!!
So as you can see from the new pump I made sure the outlet pipe was pointing upwards!
Anyway all tested and no leaks but apparently the pumps are very susceptible to failing if the engine coolant is not changed regularly.
Hope this info is of use to fellow funsters
New pump in place
