Alde 3020 top tip (1 Viewer)
Oct 25, 2015
456
283
Devizes
Bailey 79-4t
Since 2016
My Alde 3020 control panel froze on me today in our brand new 740 and as a result showed 'overheat red fail' and NO heating or hot water! Rang my man 'that does' and he said to take off black cover on boiler unit, take out fuse in green plastic holder briefly and then put it back and bingo... All reset itself and now warm as toast
ceejayt
3,206
5,807
Stamford Bridge - Yorkshire
RS Elysian A Class
Since 2004
Useful tip - thanks
Mine was a bit iffy this last weekend, wouldn't kick in - kept turning itself off, I added a bout a litre of water to the header tank as it was a little below minimum and then it started. However then had a couple of 'gas fails' and had to stop and start it a couple of times- not sure why.
Anyone any ideas? It's pretty much a brand new system
Oct 29, 2016
4,504
52,662
Surrey
Carthago C Tourer
Make sure you have bled the gas properly run hob burners for a while, presuming gas bottles are OK not empty, check that gas regulator is working, they tend to fail with no warning, if you have done this obvious stuff then apologies, I would suggest getting it over to dealer to fix or give Alde a call as they are very helpful.
Good luck
ceejayt
3,206
5,807
RS Elysian A Class
Since 2004
It turned out to be a gas pressure problem - too much gas going to the burner so safety cut out - I then had a leak in one of the radiators - all fixed now and working well.
AMK
283
202
gainsborough
Coachbuild
Since 2014
Water in the header tank, should it not be the Alde top up fluid.
Didn't realise you can top up with water.
43,315
49,369
My previous owner never topped up with anything but water for years due to a leak, now the whole system is scaled and needs a full descale with the possibility of more leaks.
The boilers internal stat cuts out before the room stat temperature due to restricted water flow.
