Alde 3020 installed accessories
Discussion in 'Heating and Air-Conditioning' started by grumfy, Oct 18, 2016.
  1. grumfy
    grumfy Funster
    Nov 9, 2015
    64
    32
    Noth Hampshire
    How do I find out what accessories are fitted to my system. In particular what type or types of pump. I tried to get the answer to my question on the Alde stand at NEC and only left more confused. What I was told was that just because it appears on the screen and you select the accessory it doesn't mean it is fitted! Also they said just select "main manual 12v" and it will work.
    I like to think I am reasonably tech literate but the Alde manual and touch screens make little sense to me.
  2. funflair
    funflair Funster Life Member
    Dec 11, 2013
    4,902
    5,157
    Guisborough
    You should have the inline pump sat next to the boiler.
    3020-9051.jpg the pump is the bit with the blue band around it.
    As to the rest of your question I am not sure what you are asking.
    Martin
  3. jonegood
    jonegood Funster
    Jun 10, 2010
    606
    883
    Shrewsbury (sometimes)
    Wouldnt you be better off asking the makers? which make is it?
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,709
    17,325
    YO11 2BD
    Or it may have the pump in the header tank.....part of the tank cap.
  5. grumfy
    grumfy Funster
    Nov 9, 2015
    64
    32
    Noth Hampshire
    Martin,
    On the "Inst Acc" screen there is optional pump, main manual12v, main remote 12v and Main 230 v and they all have the pump symbol beside them. So I presume they are all pump type options. But by ticking their box doesn't mean they are there to use is what I was told. So how do you find out if you have them? The usual signal on the Alde panel is greyed out and you cannot select or alter does not apply to installed accessories page.
    I hope I have made myself clearer and thank you for the reference to the pump beside the boiler casing.
    Eric
  6. grumfy
    grumfy Funster
    Nov 9, 2015
    64
    32
    Noth Hampshire
    Pappajohn, that takes me closer. I now have two possible locations for pumps.
  7. Theonlysue
    Theonlysue Funster Life Member
    Sep 14, 2009
    3,044
    2,918
    Essex
    I have the same thing on my hymer, and only by contacting importer, travel world, would I know what's connected.
    Not all missing items are greyed out.
  8. icantremember
    icantremember Funster
    Sep 2, 2010
    5,221
    7,338
    Nr Watton in Norfolk
    That was a quick edit Sue.:wink:
    • Funny Funny x 1
  9. funflair
    Dec 11, 2013
    4,902
    5,157
    Guisborough
    Hi Eric
    Sorry I have only just seen this, so a quick read of the online manual and yes there is a variety of pumps, as pappajohn says you could have the optional 12 volt one in the top of the expansion tank, that should be easy to find as I guess it is in the back of a wardrobe or cupboard, you should be able to see if it has a pump in the top just behind the pop off plastic cover.
    The next possibility would be an inline 12 volt next to the boiler and you would have to lift a floor hatch or gain access to have a look, my understanding is that there are two inline pump one with manual speed setting (blue dial) and one with "remote" setting two speed so that would be controlled from the panel.
    The third possibility would be a 240 volt pump but this would be in conjunction with one of the other 12 volt options (the expansion tank one at a guess).
    Pasted from web/online manual
    Circula on Pump
    Select which circulation pump to use for the central heating, depending on what pumps are installed.
    Pump Manual 12 V. For the 12 V inline circulation pump with manual 5-speed dial.
    Pump Remote 12 V. For the remote-controlled 12 V inline circulation pump. Pump speed can also be set. Speed 2 is recommended. Speed 4–5 should only be used prior to bleeding the system of air.
    Optional Pump 12 V. For the optional 12 V circulation pump in the expansion tank.
    Pump 230 V. For the 230 V inline circula on pump.
    Auto. Automa cally selects the 230 V pump when a 230 V supply is
    detected, or the optional 12 V pump when only 12 V supply is available. Pump mode can also be set.
    Cont. The pump is continuously active. This will reduce the hot water supply. For testing the circulation pump in the summer, if room temperature exceeds 30 °C.
    Thermo. The pump is controlled by the room thermostat.
    Martin
  10. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,057
    3,458
    walthamstow east london
    I know little about alde sytems but i am a heating engineer/plumber from what ive read these systems can be difficult to fill by gravity and i suspect the pump in the header tank would be an extra to aid filling
  11. funflair
    Dec 11, 2013
    4,902
    5,157
    Guisborough
    I drained and refilled our and it was easy, the header tank is a reasonable distance above the highest radiator so I just filled that and cracked a few of the bleed point and it all filled by gravity, the header tank pump is for circulation rather than and positive pressure so would not particularly aid in filling and once the pump is in place you can't add fluid.
    Martin
  12. grumfy
    grumfy Funster
    Nov 9, 2015
    64
    32
    Noth Hampshire
    Martin, thanks for the information. I do not have my van at the moment but hope to retrieve it from the dealers clutches soon. Armed with your guide I will have a good look to see what pump or pumps are fitted. I will report back on what I unearth.
    Eric
    • Funny Funny x 1
  13. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,057
    3,458
    i bow to your greater knowledge martin only one ive seen only had a single pipe down from the header tank
    • Like Like x 1
  14. funflair
    Dec 11, 2013
    4,902
    5,157
    Guisborough
    Hi Steve
    Martin
  15. funflair
    Dec 11, 2013
    4,902
    5,157
    Guisborough
    Hi Eric
    Thanks for the question, I have learnt a bit as well,
    If you find this pump at the side of the boiler, with the blue speed control knob on the end then it is the main 12 volt (not the remote one).
