Alarming using parking censors
Discussion in 'Motorhome Chat' started by Romatone, Feb 13, 2013.
  1. Romatone
    Romatone Read Only Funster
    Dec 7, 2012
    46
    23
    Sible Hedingham
    I read in a post recently of someone using parking censors as another way of providing security around the motorhome, sounds a good idea to me . I see Halfords are offering some at half price. Has anybody done it ?? If so perhaps you can post a reply.:thumb:
    Romatone
  2. darklord
    darklord Read Only Funster
    Apr 28, 2011
    1,241
    1,243
    essex
    Check online, I dismissed a kit a fitter bought at work for his dads BMW as "cheap chinese tat". Whwn the kit turned up TWO DAYS later, it had everything i it, even the bleddy drill to drill the holes. all for £13.99 inc postage, and it works a treat:Eeek:
    A couple of them positioned around the van would make a good "spacial" alarm.
  3. chesterfield hooligan
    chesterfield hooligan Funster
    May 12, 2009
    1,020
    473
    Stanton Hill
    :Rofl1: fit below the doors would work :Rofl1:
    :Rofl1: one kit would do it :Rofl1:
  4. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,170
    16,613
    Liverpool.
    It was me that posted on another thread about the parking sensors. My mate set them up in his camper by all the windows and hab door. He did not have a drivers door so none there. From what I remember he had a red LED attached to them, one pointing outside attached to the inside of the window on the hab door side so that if anyone was within 1 metre of the door it started to flash, and they could see it. He had another LED fixed above his bed so it alerted him. He also had some fireworks by the bed that he would toss out the window on the other side of the van if they did not go away.
  5. oldun
    oldun Read Only Funster
    Mar 23, 2008
    748
    160
    St Neots
    What do they protect against?
    Casual pedestrians strolling by. Is it against the law to get within a certain distance of a motorhome?
    I must be missing something.
  6. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,615
    2,189
    Rutland
    Your just missing the fact that some motor homers would like to know if someone is within a meter or so of their van in the middle of the night when it's too Late for social calls!
    Could also come in handy if your wild camping in the woods and need a shit,it would let you know if the bears about.
    :Rofl1::Rofl1::Rofl1:
    Vlad
    • Like Like x 4
  7. Snowbird
    Apr 24, 2009
    10,170
    16,613
    Liverpool.
    Not many casual pedestrians strolling by on the wildings I use.
    • Like Like x 1
  8. hilldweller
    Dec 5, 2008
    26,859
    25,726
    Macclesfield
    Or something or some wind.
    These things do not discriminate.
    • Like Like x 1
  9. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,348
    9,788
    some car alarms have a proximity sensor, which you buy as an add on. This will draw less current and give two perimiters. first one normally gives a short beep at about 5 ft and the second sounds the proximity alarm. usually a constant beep but posh ones have a verbal warning. then if the threat does not move away within a set time it triggers the main alarm. should be asier to set up than parking sensors and LEDs + fireworks and even works when your not there
    Mind you, why not just fit the full alarm system. you can even get one that texts your phone if an alarm is triggered when your not near your van. makes more sense to me, and not expensive by comparisson to a lot of items we fit to our vans
  10. Snowbird
    Apr 24, 2009
    10,170
    16,613
    Liverpool.
    The idea of this is not for when you are away from the van. Any self respecting motorhomer will have an alarm fitted. These are for use when you are in the van and in the middle of the night and want to know if anyone is prowling around outside your van, perhaps trying to nick your bike or worse still trying to force entry.
  11. TheBig1
    Nov 27, 2011
    7,348
    9,788
    but with a proximity alarm system, you can set it whilst using the van and turn indoor sensors off. fit a loop system for bikes/trailers and its all protected by an alarm that takes no further user input than pressing of buttons
  12. Snowbird
    Apr 24, 2009
    10,170
    16,613
    Liverpool.
    Of course...but if you already have an alarm fitted and its not compatible with all this new stuff, this system is a cheap fix. If money is no problem then just take the van into some garage and pay them to rip out a perfectly good alarm system and have an all singing all dancing one fitted.
  13. Stewart J
    Stewart J Funster
    Jul 1, 2010
    1,475
    1,324
    SW Northumberland
    Think its a good idea (without the fireworks) as an addition to an existing alarm without going to the expense of a new alarm system incorporating proximity sensors. :thumb::thumb::thumb:
  14. TheBig1
    Nov 27, 2011
    7,348
    9,788
    absolutely no need to rip out a perfectly good alarm, or use a garage for that matter... the add on kits give either a positive output trigger or a negative which can be wired to work with any alarm system no matter how old. in fact the older ones are easiest as the door and bonnet triggers are a crude negative input. wire this to a proximity kit, and if it triggers, it turns the cab lights on.... simples :thumb:
  15. TheBig1
    Nov 27, 2011
    7,348
    9,788
  16. Barclaybasher
    Barclaybasher Funster
    Apr 13, 2012
    2,461
    7,280
    Derby
    Great idea ! - might warn you of foxes aproaching - oops sorry wrong thread !:Rofl1:
    • Like Like x 1
  17. teddybard
    teddybard Read Only Funster
    Aug 21, 2012
    7,610
    8,996
    warwickshire
    Burglars should be culled anyway:Eek!:
  18. Romatone
    Dec 7, 2012
    46
    23
    Sible Hedingham
    Re Park Censors
    Thanks Snow Bird ..I personally think it sounds a good idea, unfortunately some don't agree but I'm not asking ....them.... To fit them. Not sure about the fireworks though, I kinda like the silence of a catapult:Rofl1:.
    Romatone
    • Like Like x 3
  19. Romatone
    Dec 7, 2012
    46
    23
    Sible Hedingham
    Oldun .....parking censors
    Thanks for your input Oldun its just something I read on a post. You don't have to have it live all day but I would think it strange to have casual walkers say from 11 pm til early hours,
    Romatone
  20. chubadub
    chubadub Read Only Funster
    Jan 25, 2013
    3
    Mansfield area
    Ive had parking sensors fitted to my M/home for 3 years now, but they were made redundant due to the dogs letting us know of imcoming from about 10mts :Doh:
