Alarm went off at 2.00am this morning. (1 Viewer)
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
The alarm on my van went off and when I got out there noting was seen to be tampered or open, I reset it and went back to bed. This afternoon I checked and found that if I pulled hard at the front nearside bonnet flap ( a Hymer A class) where it is against the headlight The microswitch set the alarm off. Why should anyone do that? They can't get anything in there or is the alarm just a bit sensitive. I am just a bit paranoid as it is the only new thing I have ever had and the dearest. The only other thing is my neighbour has a long drive over the fence and his Mercedes car has a very deep exhaust note not noisy but very low frequency, can that set the ultrasound sensors in the hab area off?
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
I'm pretty sure a spider set our alarm off .. Oh yeah and the mouse deterrent thingy sets it off too
Dazzlin
1,751
6,213
La Marina, Costa Blanca.
1986 Hymer A Class
From 2013
[QUOTE="GWAYGWAY, post: 1960324, member: ]This afternoon I checked and found that if I pulled hard at the front nearside bonnet flap [/QUOTE]
How many flaps did you need to pull to set her off? :whistle:
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
5 years, feel free to ask me about the Carado!!
Used to be a Standard crim trick, keep setting off the alarm until the owner deactivates it......then nick the vehicle!! Or maybe break in ?
Minxy
32,623
66,460
E Yorks
Carthago Compactline
Reminds me of a former work colleague who had problems with her house alarm - she'd set it for the downstairs when going up to bed and it kept going off every now and then overnight ... they eventually found out it was a massive spider that kept swinging in front of the hall sensor!
She didn't know whether to be happy that they'd found the reason for it going off, or scared to death at the size of the spider! :LOL:
DuxDeluxe
14,652
72,598
Planet Zog
A woosh bang van
since 2008
One of our false alarms a few years ago was a spider actually in the unit. How it got there, nobody knows..........
The only issue we had with our Strikeback alarm was a "dry joint" with the bike loop. Got a waterproof automotive connector and no issues since then
Aug 6, 2013
11,950
16,556
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I can confirm that a passing radio amateur, chatting with his friends, will set off many house and car alarms.:sneaky:
Feb 4, 2016
2,784
2,128
West Sussex, UK
Hymer B680 Starline
Long term a few years now.
A phrase ive never heard , a passing radio amateur . You live and learn (y)
icantremember
8,328
17,539
Near to Watton in Norfolk
Hymer T-SL668
since 2005
.......so can police car radios!
We had an alarm system on our business premises which called us when activated. On a couple of occasions I arrived in the scarey wee dark hours only to find cop cars already in attendance only to find they had been parked up close by having a nap break and used their radios.:rolleyes:
R
Robert Clark
How do you know it was the bonnet sensor that set the alarm off?
Minxy
32,623
66,460
E Yorks
Lenny HB
53,308
149,492
On the coast in West Sussex
Hymer B678 DL
Alarms can be a bit techy at times, if you think it is the bonnet switch just adjust it they are mounted with a long thread you can loosen off the locknut and wind it out a bit to make better contact then hopefully it won't go off again.
We have had our alarm go off on occasions, leaving a rooflight open in windy conditions trips the internal sensors & leaving the heating on does it, I must remember to turn off internal sensors when leaving roof lights open or heating on.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
We were at the Southport Air-show and when the jets came past they were greeted by a whole load of alarms in the car park going off. So yes, it is possible.
One reason for ultrasonics being replaced by PIR in building alarms, they can be triggered by non attack events.
Jul 6, 2016
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
The engine bay is a very aggressive environment for an alarm bonnet switch. If the OP has a plunger type switch then take it off and give it a good clean to get rid of any oily residue or condensation that could cause a short circuit.
My Hymer had a reed switch (contained in a white plastic elongated box thingy). My alarm kept going off at odd times. I found that the terminals had corroded where the 2 wires connect. These were cleaned and solved the problem. The reed switches can become a little temperamental over time but you can easily test them to check if they are opening and closing properly (bench test using a multimeter).
If you are replacing a reed switch just be aware that there are two types - NO (normally open) and NC (normally closed). The NO one is the more common but mine was the NC variety.
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
Our Vulcan always set off loads of car alarms, much to our amusement.
A couple of years ago at Shoreham it managed to crack the windscreen of one car. Fortunately the owner was a Vulcan fan and he was dead chuffed when he came over to tell us. :):)
Richard.
