Alarm going off
Discussion in 'Tech/Mech General' started by june123, Jul 31, 2013.
  1. june123
    june123 Read Only Funster
    Jul 12, 2012
    350
    134
    Staffs
    John needs help please. Our van alarm is going off a few times night and day. We don't think it is a resident fly as we have sprayed the interior. We've even checked for mouse droppings. Has anyone else had the same problem?
  2. Hayleylulu
    Hayleylulu
    Feb 17, 2008
    5,391
    3,881
    Full timing in the van
    Have you looked for a goest :Rofl1::Rofl1::Rofl1::Rofl1:
  3. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,346
    34,941
    You might get some appropriate information from This Thread of a couple of days ago.
    Hopefully it won't mean the expense of a new alarm as it did for us a few years ago.
  4. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    9,931
    11,387
    E Yorks
    We had a problem on a previous motorhome and it turned out to be the fuse for the alarm that wasn't being held 'tight' in the holder so the contact wasn't great and the alarm therefore thought it was being tampered with occasionally!
    If you can find the fuse holder(s) - probably somewhere under the bonnet or under the dash inside - try pushing the fuse well in and taping it in place and see if that sorts it out, it did with ours! If you have trouble locating the holder try looking for it at night with a torch as it will 'glint' when the torch goes anywhere near it - that's how I found mine after spending hours looking for it as it was hidden behind some other wiring under the lower centre part of the dash.:RollEyes:
  5. motorhomer
    motorhomer Read Only Funster
    May 17, 2008
    578
    317
    South Shropshire
    Most alarms have a light somewhere - usually on the dash - that flashes a code that identifies what set it off. The meaning of the code should be in the instruction book. You can then check that sensor.
    I had this problem and in my case it was the bonnet sensor, which was a little loose. 2 minute job to fix it once I knew what is was.
