Al-Ko torsion bar greasing.
Discussion in 'Base Chassis Section' started by savantuk, Nov 23, 2009.
  1. savantuk
    savantuk Read Only Funster
    Jul 3, 2009
    751
    37
    Cumbria, Lake district UK
    Hi,
    My van is going for a service tomorrow, to include cambelt, new discs and pads. I'd like the chassis to be properly serviced, and I know that AL-KO specify that the torsion bar suspension has to be grease.
    Unfortunately, I can't find the chassis manual:Doh:
    As I understand, and from memory, the rear has to be jacked up, and then has to be greased via the nipples. This much is obvious, but I have forgotten the greasing instructions. IIRC, it is 5 - 7 strokes of the greasegun until fresh grease is seen exiting the bushes??
  2. ingram
    ingram Read Only Funster
    Aug 9, 2008
    87
    I can't help with the specific question Doug, but has your service garage confirmed that they will grease it? I have heard from some people, when they were trying to get their Alkos greased, that some garages don't even have grease guns now!:Sad:
    Harvey
  3. geofliz
    geofliz Read Only Funster
    Feb 3, 2008
    88
    Worcestershire
    Yes I was told this by my Garage. I have had to do it myself with the help of a mechanic friend on the first occaision. With regard to the method you are right Doug that Alko say 6or 7 pumps on the gun, but that has never worked for me. I have had to put much more than that in to get any sign of discharge from the bushes. I tend to do it twice a year to be sure but it is a heck of a job to get underneath.
  4. walburga
    walburga Funster
    Aug 20, 2007
    300
    99
    Leyland
    I've just bought a 2004 reg Hymer B614 with the Al-ko rear axle.
    A few questions -:
    What grease can you use, recommended or otherwise ?
    Can you jack up one rear wheel, grease the axle, lower it, then do the same with the other side, or does the whole axle need to be off the ground ?
    Whereabouts on the axle are the bushes through which excess grease will be expelled ?
    There is mention of the procedure in the literature that I got with the van, but it is a bit sparse with no pictures.
    I've still got my high pressure grease gun from my MG kingpin days !
    regards
    Allen
  5. savantuk
    Jul 3, 2009
    751
    37
    Hi,
    I doubt that the torsion bar runs the width of the axle - it would defeat the object. I imagine therefore that you could easily do one side at a time.
    I have both a German and English manual from mine. The German manual tells you it has to be done, and how to do it (except amount of grease needed), and the English one dosen't mention it, though I had printed the instructions inside the rear cover. The manual must have disappeared during the last sevice.
    The German manual recommends the following grease:
    Costrac GL 1501 or
    Cardex 3746 SP
    I haven't heard of either, but I'm sure your workshop has a compatability chart.
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,100
    17,769
    YO11 2BD
    the rear axle must be clear of the ground on both sides simultaniously and not jacked up under the axle. you need to jack under the chassis itself.
    on some alko axles there are two nipples on both sides.
    use hard wooden blocks so as not to dent/crease the chassis
    if memory serves its 6/7 strokes of a manual grease gun...(i wouldnt use a powered gun)...whether grease appears at the axle ends or not.
    any grease that does ouze out will appear from the very end of the axle tube where the swing arm joins on.
    if any ouzes out theres no point pumping more in:Doh:
  7. SIFTA SAM
    SIFTA SAM Funster
    Jan 27, 2009
    480
    492
    Leyland Lancs
    AL-KO man at the NEC said that as the torsion bars do not go the length of the axle, you can lift (and grease) each wheel independent of the other, but I have got into the habit of elevating both wheels prior to greasing.
    GL 1501 (Kluber) has been replaced by Kluberlube BE41-1501
  8. Burstnerite
    Burstnerite Read Only Funster
    Jul 27, 2009
    10
    Lincolnshire
    Re. ALKO chassis greasing
    Hi,
    I E-Mailed ALKO and received the following response :-
    The Castrol LM grease can be used with a hand operated grease gun (this is what we recommend not a pressurised gun) . You will need to raise the wheels clear of the ground; this then allows the grease to circulate around the swing arm journal. By raising the wheels one at a time will allow the grease to reach the correct areas.
    Regards
    Alan Sanders (Service Manager)
    Hope this helps,
    Jim
