AL-KO suspension (1 Viewer)
Uncle-Steve
20
Hi,
Can anyone help please?
I'm looking for an exploded diagram of the AL-KO torsion bar axle and how its assembled (showing torsion bars etc.) please. Ideally of a 2007+ axle, but earlier ones will be fine.
Thanks in advance for any help :Smile:
theresa
325
near falmouth cornwall
c class
15 years
Hi,
you can always try and get hold of AL-KO them selfs , we had a problem on one of our older vans and they were very help full , they may e-mail you a diagram
Uncle-Steve
Uncle-Steve
20
Thanks for your post ::bigsmile:
I could approach AL-KO, but I tend to find people like them want a chassis number etc. which I don't have :Sad: hence posting on here as some kind sole is bound to have something immediately to hand.
Here's hoping :Smile:
scotjimland
2,231
9,714
A Woosh bang
Hi , don't know if this is much use, page 10 has some detail ..
Link Removed
If you haven't already found it there is a AL-KO support submission form and phone number here
Al-Ko Kober
jim
Uncle-Steve
Uncle-Steve
20
These are handbooks for motor home chassis and caravan chassis. They may be of some help.
Link Removed
CaravanChassisBook.pdf (application/pdf Object)
Hi Doug, thanks for the links ::bigsmile:
They don't show exactly what I want (exploded diagram of the MH suspension showing the torsion bars etc.), but it does confirm the caravan suspension uses rubber and not steel for the springs as I was talking to someone who was under the impression there was rubber in the MH suspension, where as I believe its solely steel torsion bars.
I'll go an interrogate the links further.
Thanks :Smile:
DESCO
2,646
266
London
low profile
18 years +12 years tugging
I can't find the diag I was looking for but I am certain that there is square section rubber, think it was 4 round square steel rod, will keep looking.
Dave:thumb::thumb:
43,289
49,223
maybe of no use but the bottom pic shows the axle at rest with the arm removed.
it will give you an idea of the positioning of the rods.
up to '97 they had torsional leaf springs then '97 onwards.. torsion rods.
Vehicle Technology > Automotive > Axle Technology > Axle Design
All AL-KO amc axles are longitudinal swinging arms, with independent suspension. Depending on the suspension type, a difference is made between torsion bar suspension axles Fig. 1 and air suspension axles Fig. 2.
Fig. 1
Fig. 2.​
Key to Fig.1 & 2.
1 Axle Brackets
2 Axle Brackets
3 Swing arm with inner tube
4 Spring elements (torsion bars)
5 Air Bellows
6 Bellows Bottom Bracket
7 Bellows Bracket Top
Torsion Bar Suspension:
Type BT – up to model year 1997
A spring assembly made from individual spring leaves serves as a spring element. These spring assemblies differ in respect of the cross sections, the layering of the leaves, as well as the spring lengths – dependent on axle load and the spring characteristics required.
Type BTR1/BTR1.5/BTR3/CA3
6 torsion bars per axle with splined toothed bar ends, serve as spring elements.
These torsion bars differ in their technical design dependent on the respective permitted axle load and the relevant axle side.
lebesset
760
I have stripped 2 caravan chassis made by alko ...they both had steel torsion bars
