Akura 21.6" LCD/DVD tv fault
Discussion in 'TV & Satellite' started by pappajohn, Jul 20, 2011.
  1. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,126
    17,793
    YO11 2BD
    anyone else have one of these TV's ?
    do you have a problem with the remote control not responding if aimed from the left hand side ?
    then i have the solution :thumb:
    the problem is the remote magic 'eye' doesnt line up with the 'lens' on the front of the tv and can only be seen from the right hand side.
    from the back of the tv, remove the screws around the edge holding the front panel in place.
    (10 i think, one screw is recessed in the stand bracket)
    turn over and carefully unclip the front cover and lift off.
    it's on molded clips on each side and needs a knife or small screwdriver between the front and back panels to ease it over the clips.
    the magic 'eye' is mounted on the front panel and has a short, flat lead running to it.
    undo the two screws and lift out of the way.
    very carefully cut away half of the screw pillar nearest the corner of the panel.....cut to a depth of around 1/4"....to allow the small PCB to be repositioned further to the side.
    line up the magic 'eye' with the lens and, as the screw holes no longer align, superglue back in place.
    my TV can now 'see' the remote from just about any angle. :thumb:
    • Like it Like it x 1
  2. chatter
    chatter Read Only Funster
    Aug 3, 2009
    3,723
    940
    cheshire
    not that i would try to do that, but saying that havent noticed a prob with either of our 16" akuras
  3. chrisgreen
    chrisgreen Funster
    Jul 26, 2009
    5,642
    7,748
    england
    and if the above fail's get up and use the button's on the telly:Rofl1::Rofl1:
    sorry papa could not resist:thumb:
    good tip though:thumb:
  4. pappajohn
    Aug 26, 2007
    30,126
    17,793
    YO11 2BD
    Buttons on the tv.....do they still fit them ?
    havent used those for years :Laughing:
  5. pappajohn
    Aug 26, 2007
    30,126
    17,793
    YO11 2BD
    probably just the 21.6" model and more than likely a batch of 'alternative' sensors from a different supplier. :Doh:
