airlock in water pump
Discussion in 'Motorhome Chat' started by Goldenoldies, Jun 11, 2013.
  1. Goldenoldies
    Goldenoldies Funster
    May 10, 2012
    405
    851
    Wiltshire
    We have just driven from mid Wales to Blackpool, the fresh water was showing 25% just topped up to 100% and now the pump runs on, is it an airlock if so how do I cure it. All advice would be grateful. Thanks.
  2. icantremember
    icantremember Funster
    Sep 2, 2010
    5,450
    7,551
    Nr Watton in Norfolk
    Check you haven't left a tap open anywhere and look around for any possible leaks.
  3. Terry
    Terry Funster
    Dec 27, 2007
    10,784
    6,293
    South yorks
    Hi you have either a leak -look for water in or under van :BigGrin: or the seals on the pump have gone :thumb: new seal set or new pump -seals are about 15 quid ish new pump from around 50 quid up --a fifty quid pump will more than likely do the job instead of replacing like for like.
    Assuming you have opened the tap slowly to relaese any air out of system :BigGrin:
    terry
  4. Terry
    Terry Funster
    Dec 27, 2007
    10,784
    6,293
    South yorks
    Prety certain the is a mobile fitter around Blackpool --prob a lot cheaper than a dealers -sorry no idea on a name :Smile: poss, caravan doctor -
    terry
  5. vwalan
    vwalan Funster
    Sep 23, 2008
    7,669
    3,949
    roche cornwall
    could try having pump running and sucking on the tap. does work sometimes .
    best not try the shower .ha ha
    • Like it Like it x 1
  6. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,418
    5,442
    East Sussex 01-580-881288
    Try giving pump a tap with a hammer, maybe the pressure switch is stuck
    Peter
