aircon recomendations?
Discussion in 'Heating and Air-Conditioning' started by tommytli, Aug 14, 2011.
  1. tommytli
    tommytli Funster
    May 26, 2009
    443
    26
    lancashire
    after my recent trip to italy im wanting aircon, any recommendations? do they run on 12v aswell as 240? are they quiet?
  2. W18BLA
    W18BLA Funster
    Oct 24, 2009
    348
    34
    West Midlands
    I have the Dometic 2600 with 12v addon it is good abit noisey on cooling but when its at its optimum temp it sits there nice and steady, But the one we have is climate control, And then there is the cost £3k fitted alot of dollar..:cry:
    Craig
  3. dennismartin
    dennismartin Read Only Funster
    Jul 26, 2011
    135
    19
    hull
    hi
    i have just got a dometic 2100 from olearys £450 new but old model
  4. tommytli
    tommytli Funster
    May 26, 2009
    443
    26
    lancashire
    do you have a link?
  5. dennismartin
    Jul 26, 2011
    135
    19
    hull
  6. dennismartin
    Jul 26, 2011
    135
    19
    hull
    dont go for the smaller ones that he has
  7. dennismartin
    Jul 26, 2011
    135
    19
    hull
    you will nead a 3 kw inverter to run this you can pick them up for £175
  8. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,493
    894
    South Glos
    And how many batteries will you need to power it :Eeek:
  9. dennismartin
    Jul 26, 2011
    135
    19
    hull
    i have only just set mine up on inverter today not tested it but it will use a lot of amps i think about 85 im sure some one will give you the answer it is a 900 watt air con 1200 watt heater
    i will only use mine on inverter while travelling as and when needed 1 have 4 115amp batteries 300watt solar panels not that they will do much
  10. tommytli
    tommytli Funster
    May 26, 2009
    443
    26
    lancashire
    so am i right in thinking unless you have a good electric supply you cant have the aircon running at night while sleeping?
    and if thats the case while i was in italy and needed it the most and the 3 and 6 amp supply would have not been enough to run it?
  11. scotjimland
    Jul 25, 2007
    28,983
    25,680
    Yes and no..
    The smallest Dometic has a cooling capacity of 1kw , uses 2.1A , this will run on a 3A supply but MAY trip the ehu breaker on start up .. so if you really want one it's worth the risk.. provided you can reset the breaker without having to wake the site commandant ..
    Cooling capacity (kW) 1.0
    Full Load, cooling (A) 2.1
    Capacity (BTU/h) 3400
    Power (V/Hz) 230 / 50
    Refrigerant R407c
    Dimensions (L x W x H) (mm) 980 x 650 x 235
    Dimensions (roof opening) (mm) 400 x 400
    Net weight (kg) 29
    Circuit (A /sec) 11/0.15
    Consumption, cooling mode (W) 500
    Consumption, heating mode (W) 800
    Fan speed (kW) 2.0
    Fuse (A) 3
    Roof thickness (mm) 25-45
    http://dometic.com/enie/International/Site/Caravan/AirConditioners-Ventilators/product/?productdataid=66587
  12. tonywolst
    tonywolst Read Only Funster
    Jul 22, 2011
    81
    28
    Shropshire
    I have one but cant remeber the exact model number Think Its a dometic B1500, Cost me £300 and i fitted it myself(dead easy), Only triped out the ehu once when I put the kettle on at the same time by mistake, Im only 6m long and it worked perfectly, the noise never botherd me as I couldent sleep with the heat, I rekon its the best thing i ever did:thumb:
  13. motor roamin
    motor roamin Funster
    May 23, 2010
    1,535
    785
    Leicester
    Jim I might be talking out of the wrong hole :Rofl1: I am a mechanic not a sparky, but couldnt start up be softened so as not to have such a surge on start up.
    All the best Rick
  14. 1948
    1948 Read Only Funster
    Dec 3, 2009
    444
    46
    surrey
    can you tell me where I can buy one Thanks
  15. jezport
    jezport Funster
    Oct 29, 2008
    1,935
    1,308
    West Yorkshire
    We have an aircon unit fitted in our double floor, its a Truma model, it is very quiet unlike the roof units I have heard. We fun it on fan only on a 500w inverter while traveling.
  16. eddievanbitz
    eddievanbitz Trader - Funster
    Oct 4, 2007
    3,905
    12,088
    Taunton Somerset
    All Dometic units are have "soft start" relays. If fitted by a DMC (Dometic Motorhome Centre) you will get a three year parts and labour warranty and many (we do) will offer free fitting over the winter period
    Hope this helps
    Eddie
  17. scotjimland
    Jul 25, 2007
    28,983
    25,680
    didn't know that Eddie... thanks for that ..
    do you have any technical details.. ?
    jim
  18. dennismartin
    Jul 26, 2011
    135
    19
    hull
    3kw inverter off ebay runs all electrics great
  19. eddievanbitz
    Oct 4, 2007
    3,905
    12,088
    Taunton Somerset
    Hi Jim
    No not really, the thing is that Dometics marine division is huge and has a range of devices to stop problems with generator and shorepower conection. So other than telling us that they're soft start we don't get told that much
    We use a soft start relay kit designed for halogen lights (patio heater type) to elliminate the problem of tripping the site when connecting RV's up usually caused by the transformers.
    So we assumed that Dometic crossed a bit of technology over from their Marine devision
    Eddie
    • Like it Like it x 1
  20. scotjimland
    Jul 25, 2007
    28,983
    25,680
    be aware , you will need a big battery bank to use a 3kw inverter
    3kw from a battery at 12v will pull 250amps .... how long will 100ah battery last ?
    about 12 mins..
    also, leisure batteries are not designed for heavy loads ... to use this size inverter at full load you would need a bank of traction batteries.. and a trailer to carry them
    by all means use an inverter but do the maths before buying ..
