Air system on suspension? (2 Viewers)
Lloydsinspain
9
3
Alpujarra. Spain
Hymer B534
Newbies
hi us again :)
We've got an 'air system' on the suspension, the gauge and filler is behind the drivers seat. It's a 1993 Hymer b534 fiat ducato/a. Can anyone explain what it is? What and how to use it?
Also does anyone know where we can buy a replacement diesel filler tube and connector to the wing. The diesel filler has come away from the wing. Although we are in Spain it's easier to order stuff from the UK! Not found any good suppliers here, as yet!
Cheers :)
MikeD
3,936
3,697
London
IH PVC
Since 2012
The air suspension on my motorhome is made by Dunlop.
We had it fitted because the rear suspension sagged a fair bit and gave us ride height problems.
So I can put a couple of bar air presssure in the system and the back end raises a couple/three inches.
It could also be fitted to allow a up-grade on the maximum weight of the motorhome. ie: 3500kg to 3850kg.
We also use ours to level the motorhome on site. Ours works independently on the rear suspension only so I can raise or lower it both back to front and side to side.
Have a look at:
Broken Link Removed
