Air suspension
Discussion in 'Motorhome Accessories' started by Shuismo, Aug 26, 2013.
  1. Shuismo
    Shuismo Funster
    Oct 23, 2012
    104
    33
    se london
    Hello,
    How much lift should you expect when using air suspension.
    We fully deflated the bellows took measurement from the ground then inflated them to seven upon measuring we only had a diffence of 2 centimetrersnot a lot I think you will agree anyone with info
  2. icantremember
    icantremember Funster
    Sep 2, 2010
    5,456
    7,554
    Nr Watton in Norfolk
    What make air suspension do you have?
    Our AS system only gave around 35mm to start with but Phil fitted some spacers which have given us another 25mm approx
  3. Shuismo
    Shuismo Funster
    Oct 23, 2012
    104
    33
    se london
    As
    Thank you for your reply, it seems our AS is the same as yours. When we took measurements we deflated the system fully which I considered the first reading to be zero at this level from the ground. Then we inflated the bellows to between 7 & 8 bars and took another reading which registered 20mms lift. Is this what I should expect, or is this not the correct way to measure?
  4. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,320
    8,028
    West Norfolk
    You might find, after a drive, the air will heat up, increase in pressure and give more ride height. This will settle again once things cool though.
  5. voyagerstan
    voyagerstan Read Only Funster
    Aug 7, 2011
    323
    211
    torquay sometimes
    its not realy for lift only for stability . you need higher spring rating for lift . lifted mine 5 ins with re bent springs + 2 all round for a lot more ground clerance . :Wink: stan
  6. BwB
    BwB Funster Life Member
    Apr 3, 2011
    612
    567
    Suffolk UK
    I have Air Ride at the back (similar system) and I get about 5cm difference.
  7. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,812
    1,030
    Cark, Cumbria
    Are you measuring at wheel arch or rear bumper as there is a big differance?
  8. mentaliss
    mentaliss
    Nov 2, 2012
    657
    308
    Lancing
    I agree, the Dunlop information I received when I fitted mine is absolutely not about ride height more to do with spring rebound, stabilizing the rear when corning, also noticed when passing a 'train' of juggernounts yes you can increase the height but that's really controlled but the springs, after all the original Bump stops did not control the axle height:Wink:
  9. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,926
    10,300
    supplemental air suspension as is retrofitted to motorhomes merely replaces the bump stops. therefore it will hardly increase ride height, it just limits the amount it compresses by. in other words it firms up what is already there:thumb:
  10. Shuismo
    Shuismo Funster
    Oct 23, 2012
    104
    33
    se london
    As
    Thank you everyone for the input, it seems we were under the wrong impression, we thought AS would give us rear wheel lift as some of the adverts inferred. Thanks again
