air suspension.
Discussion in 'Motorhome Chat' started by busby, Jun 7, 2013.
  1. busby
    busby Funster
    Aug 18, 2011
    3,521
    3,340
    derbys
    Any one know how much it costs to have air suspension supplied and fitted? BUSBY.
  2. TheDogMan
    TheDogMan Funster
    Mar 29, 2011
    683
    391
    Rugby UK
    AS are about £700 up according to your chassis, great result for me !!
    I am not a DIY person
  3. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,542
    9,968
    £400 for the kit and 2 hours to fit it. so even if you get a local mechanic to fit it, you should only pay £550 maximum
    its not rocket science to fit the air springs so pretty much anyone with the tools can do it. in fact its so easy there are companies that fit it at the shows, so no garage needed if you are slim enough to slide under the van and cable tie the hoses
  4. JJ
    JJ Funster
    May 1, 2008
    14,770
    26,414
    My memory is not the sharpest knife in the drawer but...
    1. A friend of mine and I fitted airbag assisters to his Boxer parked by the side of a beach in the Algarve in about an hour and a half so a garage should be able to do it in less time. The airbags and fittings were aroundcthec £300 mark.
    2. A garage owning Funster friend fitted airbags to my Iveco in an hour using a pit and with access to all the tools... the bags were under £400.
    So... I think you might find a more affordable quote than £700 unless you are going for the (unnecessary in real life) on board compressor and buttons as well.
    Mind you... what ever you choose to pay, once fitted, I believe they will improve your ride dramatically.
    JJ :Cool:
  5. Ed Excel
    Ed Excel Funster
    Nov 27, 2012
    869
    577
    Ribble Valley
    A simpler alternative to air bags is these:
    http://www.rubbersuspension.com/
    They are easier to fit than the bags and they will never pop. I imagine, with air bags, if you go for onboard controls it will be like variable speed wipers, they're never at the right setting.
    I had a specific problem with very hard suspension, the van crashed on nearly every bump in the road. The hollow rubber springs are softer than the OE assistors and have proved quite successful.
    Also, the don't cost half as much
  6. JJ
    JJ Funster
    May 1, 2008
    14,770
    26,414
    The rubber thingies look interesting and I am sure they work well.
    But even without the onboard compressor etc the airbags are simplicity itself to inflate and deflate if you want to adjust your suspension for different loads/conditions...
    JJ :Cool:
  7. SandJ
    SandJ Read Only Funster
    Sep 14, 2007
    1,558
    518
    North Yorks
  8. Peter & Elaine
    Peter & Elaine Funster
    Aug 30, 2012
    3,994
    6,499
    Roobarb land
    Same here took 1 day to fit tow bar and airbags
    A grand all in :Sad:
    No problems at all and nice people :thumb:
