Air Suspension (1 Viewer)
Redjumpa
148
44
North Lincolnshire
5 years
Hi guys
My air suspension has had a catastrophic failure and cannot be repaired.
I can't afford to replace it at the moment and wondered if it's safe to drive as it is and if not what should I do with it.
Snowbird
11,818
22,345
Liverpool.
Fifth wheel.
Since 11-05-2000
What sort of catastrophic fail. There is not that much to go wrong with them.
reader
185
73
IO83rk
It could be something as simple as a valve failure in which case a tyre valve core can be fitted very quickly. Other than that it may a union has come loose or a burst pipe but airbags themselves are pretty robust items
Redjumpa
Redjumpa
148
44
North Lincolnshire
5 years
Both airbags are split and I can't source replacements due to their age. I've been told the only option is to fit a complete new system. Maybe I need a second opinion?
Apr 21, 2009
546
34,640
East Cowes, PO32 6RU
Caravan
Caravan since 1970, motorhome or RV since 1999 then back to a caravan in 2017.
From my memory of the Hymer (I used to run a 694) the manufacturer's suspension would not have been air and so, I suspect, your air bags are an after market add on to improve the ride and possibly increase the load capacity.
If yours has not been 'up plated' to carry more load due to the addition of the air suspension, and the broken parts are not in any way causing problems (perhaps best to remove them), you can run without as you would still have the original suspension.
lunarman
2,147
2,438
South Glos
since 1994
The one problem there may be is that when the Air suspension was fitted the original suspension bump stops may have been removed. If you are not going to replace the bags you may have to refit bump stops.
Lunarman
slobadoberbob
6,151
1,960
Kent, garden of England
Winnebago 23' something
25 years & counting
they do not need to cost a fortune
They do not need to cost a fortune...
I imported mine from the USA from airlift and a complete system with compressor and a remote control system cost me a few pence over £300.00 over here it was over double. But firestone make a system as well as others.. it is a case of looking about.. You will be able to fit lift bags to replace what you had I am sure they come in all sizes and shapes.
Bob
Terry
11,904
8,969
Lincolnshire
Can't remember ;)
Deffo :thumb: you can buy new bags seperatly :thumb: indeed all parts can be sourced seperatly
terry
edit you should be able to drive your van with the normal pre fitted suspension - prob just a bit more body roll than you are used to
