Air Suspension
Discussion in 'Introduce Yourself' started by Jinx, Mar 23, 2011.
  1. Jinx
    Jinx Read Only Funster
    Mar 22, 2011
    Wiltshire
    I've been touring Europe for around six years in a Lunar van and have just acquired an 09 Lo line coachbuilt with air suspension. The ride and stability are serious improvements on the previous model but I don't know what pressure to run the system at. Got it set at 40 psi at the moment. Any advice or experience gratefully received:thumb:
  2. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,795
    13,704
    Norfolk
    The maximum is generally around 100 psi depending on type, you need to check that, but the setting that gives you what you consider the best ride is where you need to be.
    I have air suspension on mine and the improvement in ride and reduction in body roll was well worth the investment :thumb:
  3. Bailey58
    Bailey58 Funster Life Member
    Jun 23, 2010
    6,574
    10,197
    Norfolk and Toftir.
    I'll endorse what Larrynwin said, well worth the money. Mine was set at around 3 bar which seems fine, I'll leave you to do the conversion! :thumb:
  4. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,795
    13,704
    Norfolk
    Mines a pint please :Rofl1::Rofl1:
  5. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    for those who need to convert
    1 bar = 14.5037738 pounds per square inch
  6. Bailey58
    Jun 23, 2010
    6,574
    10,197
    Norfolk and Toftir.
    So we're drinking again, got through that bottle of whisky have we? :Smile:
  7. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,795
    13,704
    Norfolk
    Haven't started on it yet Rolf , been a bit sick but will soon catch up on lost time :thumb:
    Larry
  8. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    Hi Jinx
    Welcome to MH Fun
    On one of our earlier vans we fitted air suspension to stop sway, from memory used to run at 40/45psi depending on load. I remember to start it was a case of trial and error, before settling on those figures.
    Dave .:thumb::thumb:
  9. nomadic
    nomadic Funster
    Sep 27, 2007
    682
    180
    Shropshire based
    Hi Jinx,
    When we had a Lunar 780 coachbuilt, we also had air suspension fitted, as said it was trial and error to start, but found 50psi rear and 40 psi front gave the best stability and smoothist ride.
    We did use the same road circuit to sort it, motorway/A road and b road, over about 20 miles, but well worth the effort.
    Good luck:thumb:
Similar Threads
  1. chirpychimp
    13
    307
