Air Suspension (1 Viewer)
Fishdude
3
Gloucester
Autocruise Starfire
Newbie
Hi.
Ive just purchased an Autocruise Starfire.
On the drivers step is a gauge with 2 pipes going to it. This appears to read zero.
I assume this is something to do with air suspension.
Can anyone yell me what to do with it.
Fish
Nov 6, 2013
3,201
228,685
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
Hi @Fishdude and welcome to Fun.
I think those gauges are indeed for air assist and should not read Zero.
As I understand it, that me and the air bags are flat and will wear out quickly. I think there should be at least 2 bar in there but I'm sure you will get more experienced advice shortly.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
Minimum pressure should be about .3 of a Barr (5 psi). I usually run at 25 to 30 psi (2 Barr ish).
3,422
12,138
South Staffs
Pilote P740GJ
Since 2013
Do not drive without any air in system, i park mine up and leave about 10 psi in and run at 40 to 50 psi depending on load.
5,917
38,638
Uk
Has if got valves on the pipes,,to select which side to inflate, if so both valves maybe shut and hence gauge showing zero.
Ps I could be wrong
13,037
101,362
Bolsover, Derbyshire
Hymer S800
not long enough
It could also be that the previous owner removed the air bags when he sold it, or if he wasn't happy with them, but left the gauges so as not to leave holes on the inside
I had mine taken off when upgraded to fully automatic system, if the same as mine they are about 6" high and similar across, round rubber things, sorry not very technical o_O but they should be visible if fitted on yours by looking underneath inside rear wheels
If they are fitted, then as advised they should have air in or will be damaged, having said that, when we bought ours we didn't know it had air suspension and drove 100's miles before we found out it had and worse had no air in one side at all, no damage done (y)
Badknee
7,406
411,667
notloB
Vantage Neo
Living the dream.
Ours has a gauge and a tyre valve behind each front seat, I run ours @2bar to make it run level.
tonka
10,822
21,513
Cannock, Staffs
A class Burstner 800
Since 2000
Sounds very much like "air ride" suspension...
As said should not be empty as that will ruin the air bags..
Turn taps so they are in straight vertical line with pipes (open), connect foot pump and give them a blow up..
Pressure should hold if everything is ok..
http://airide.co.uk/
F
Fishdude
3
Gloucester
Autocruise Starfire
Newbie
Wow, thanks for the prompt replies.
looked closer and it does say air ride on it.
It does register when I pump up with a bike pump, but the adaptor is naff.. Now need to get a decent valve adaptor.
Everyone agree at 2 bar?
tonka
10,822
21,513
Cannock, Staffs
Since 2000
Play with the pressure to see what suits, try a few trips and see how the ride feels...
Mine I run at 3 bar but it's more to get my "ass" off the floor and it does catch sometimes due to the long overhang..
Lorryman100
640
1,015
UK/Scotland
Rapido A class
Have a look underneath at the rear axle and you should see what looks like rubber bellows on each side, these are the airbags. The airbag can be seen behind the shock absorber,
Broken Link Removed
My system is from VB and the gauges and pipework look like this,
Depending on the system you have fitted there are maximum pressures, the VB system is 3 bar max but after playing around with different pressures I now run mine at 1 - 1.5 Bar
TerryL
6,171
8,173
North East
Low Profile
I tend to run mine at 50 psi - gives a nice stable ride without being too hard.
Mack100
766
2,697
Swift
I'd been running our Dunlop system at 1.5bar but on the advice of the installer I upped it to 3bar. What a difference! Not only is the ride smoother and quieter but when overtaking HGV's and car transporters the wind induced "nudge" is absolutely minimal.
