Air suspension (1 Viewer)
Tony H
27
3
Leicestershire
Bailey autograph
I'm a newbie
We have a new Bailey motorhome and are very pleased with it indeed. It handles very good for a motorhome, but will air suspension make it even better? Some one has told us it will because his does, but he has an older van 07.
Look forward to any opinions.
musson
487
165
grantham
low profile
since Jan 2014
I ask this question seemed to come back with it helps what ever age I am going to fit when weather better
cost for rear kit with 2 gauges on ebay around £280 MH 2011 ducato chassis
makems
3,438
27,692
Ingleby Barwick,,Teesside
Sadly had to give up
Do you have any specific issues with the ride? If not, why spend money on unnecessary toys just because someone else them?
Sadly it's a trap we all fall into at some time or another (me included)
I did have air assist fitted to my last Van which had a Mercedes Sprinter base and which rolled around horribly on bends and uneven surfaces. Current van is Fiat based with Alko chassis so I feel no need to fit it.
tonka
10,823
21,513
Cannock, Staffs
A class Burstner 800
Since 2000
Earlier vans, maybe even up to 2007 had a van / narrow chassis.. That meant the body was a lot wider and gave excess roll.
So fitting air suspension made a big difference, i had a 2005 van and found it better the moment i drove it around first corner..
Later they bought out the wider motorhome chassis and my 2012 van seems a lot better and without suspension. I want to fit it to raise the back end but dont feel any need to add it for the ride quality.. Done almost 30,000 on all sorts of roads and I am happy with the standard chassis.. The bailey I think has a lower Alko chassis so in theory should be better than mine.
MikeD
3,936
3,697
London
IH PVC
Since 2012
Depends on which chassis is fitted.
If you have a Alko chassis I am told you don't need it.
If you have a Fiat Ducato 3650kg.
Ours is 2012 and it transformed the way the vehicle drives. No more white knuckle journeys along windy motorways waiting for the next lorry to pass us.
Ride hugely improved and without doubt the best money we have ever spent on the motorhome.
I would definitely recommend it. (y)
Lenny HB
53,283
149,408
On the coast in West Sussex
Hymer B678 DL
Bailey's are on an Al-Ko so for a Dunlop system looking at £1500 that is just for the kit.
Unless you have a load problem with the rear axle you shouldn't need it, the Al-ko chassis generally ride superbly.
215
1,314
Rochester
5years Motorhome. 25yr tugger
I have fitted Dunlop air suspension to my Bailey Autograph 740. I did it mainly to uprate the gross weight and to raise the rear because we carry a scooter on the back. Haven't noticed much difference in the handling but the tow bar doesn't hit the ground now
Badknee
7,406
411,708
notloB
Vantage Neo
Living the dream.
Yes ours was fitted by previous owner to get weight up to 3800kgs. but I do like it. I can alter the rear ride height to stop it looking tail heavy.
sparky
97
85
bingley yorkshire
a class burstner aviano i
30 years
Hi I fitted mine on a alko chasis on a burstner a class because the tow bar grounded a lot. Because of the low chassis
