air suspension for hymer with alko chassis
Discussion in 'Motorhome Chat' started by chasthedagger, Aug 31, 2015.
  1. chasthedagger
    chasthedagger Funster
    Apr 28, 2008
    82
    20
    rayleigh, essex.
    can anyone help with info on getting it fitted or getting kit for di thanksy and prices would be good.
    thanks.
  2. Mr B
    Mr B Funster
    Feb 1, 2015
    380
    971
    yorkshire
    It would help if we knew the year:)
  3. markh
    markh Read Only Funster
    Jun 4, 2014
    247
    243
    I think on the alko, you're restricted to the Dunlop system, only available for the alko chassis with compressor and gauges, you could call armitages they are very helpful, some alko chassis are incompatible so you can't have it, when I was there a guy came with a Carthago and was turned away
  4. Mr B
    Mr B Funster
    Feb 1, 2015
    380
    971
    yorkshire
    Yes. Agree with markh. Armitages have prices on there web page. Not cheap though :(
  5. markh
    Jun 4, 2014
    247
    243
    You're looking at £1550 inc Vat
  6. JockandRita
    JockandRita Funster Life Member
    Aug 2, 2007
    5,928
    9,013
    Lincs/Cambs border
    German companies, (including Goldschmitt), do air suspension kits for older Alko chassis's, which UK suppliers don't seem to cater for.
    Cheers,
    Jock. :)
    • Like it Like it x 1
  7. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,484
    888
    South Glos
    Don't know where you are but AS suspension of Warrington are generally recommended for fitting air suspension to Alko chassis. We have used them twice and they do a good job.
  8. ivorantony
    ivorantony Funster
    Jan 22, 2013
    514
    547
    London SE
  9. markh
    Jun 4, 2014
    247
    243
    Well done fitting it yourself, I build race motorcycles but decided not to
  10. Wilderbeast
    Wilderbeast Funster
    Jan 20, 2012
    76
    77
    Stockton on tees
    AS suspension will sort you out ,Phils a good bloke and knows his stuff may not be the cheapest but worth it in my opinion.
  11. SandraL
    SandraL Funster
    Jan 24, 2012
    300
    154
    Somerset
    I was looking earlier this year for 2013 van. This info from June 2015
    Dunlop Kit, currently not available due to "problem" .Usually available from Marcle Leisure. It clamps onto the van, no dismantling of hub required.
    All below insist on fitting air pump/guages, no supply only. Hub will need to be removed.
    AS in Cheshire, 01925 740666, £1700
    Gliderite, Hampshire, 01428 751711, £1245
    Travel World, Telford, 0844 8804938, dearest of the lot, they change the torsion bars as well as fitting air bags, also insist on new wheels if going over 2500kg
    VB Air, A&E Leisure, Northwich, 01606 973005, not willing to discuss as their expert was on hols.
    Court Side Conversions, Tiverton, 01844 256048, diy allowed at £1250 +vat, would also fit.
    On my 2013 van it turns out the torsion bars are same as new axle supplied by alko that is rated to 2500kg, so I have uprated rear axle from 2400 -2500kg with no physical change to vehicle.
  12. ivorantony
    ivorantony Funster
    Jan 22, 2013
    514
    547
    London SE
    The Dunlop kit I brought from Marcle leisure in August 2013 cost me £794.55 including delivery, as said previously it took a full day to fit and you definitely need to remove hubs and calipers on my Renault master running gear to fit the air bag brackets, and also needed to modify the hand brake cable to calipers to give clearance,
    As I had just retired from the motor trade it didn't present much of a problem to me , but if you are not sure how to go about removing brakes and hub assembles then I suggest leaving it to a professional ,
  13. Peter Ashcroft
    Peter Ashcroft Funster Life Member
    Aug 14, 2015
    123
    89
    Wigan
    Try this guy, hes mobile and very good
    http://www.rhinoinstalls.co.uk/airride.htm according to his website £995 for the Alko, he is doing my transit next week for £795, used him for other stuff and have no complaints.
