Air suspension & Auto levelling (1 Viewer)
Aug 19, 2014
1,855
5,564
Cliftonville
A Class Burstner
Since 2014
Do any Funsters have both?
Am considering VB full air suspension, but wonder will it give enough for levelling on sites or should I also add E&P levelling?
R
Robert Clark
For a decent levelling you really need both as the adjustment on the air suspension is not as good as the levellers themselves.
I'd not be without either of them
laird of Dunstan
1,464
3,953
lincolnshire
Rapido 9000DFH
ex caravanner
i have the E&P system ,its one of my top buys for the MH,like robert i would not be without it ,i may do the air suspension later but the new (only done 4.5k miles) MH is fine without them
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
VB will provide a modest amount of levelling. You can achieve much more with hydraulic levelling - and there's no rocking.
VB is more for the ride.
jdk62
Aug 19, 2014
1,855
5,564
Cliftonville
A Class Burstner
Since 2014
So levellers considered more desirable than air suspension?
Brian and Jo
3,002
6,447
oswestry,shropshire
A-Class N+B Arto 88F
Been motorhoming for 15yrs.had an American RV for 7yrs,Now got a Niesmann Bischoff Arto 88F
hi there we have the Goldschmitt system ,both the air suspension and the hydraulic levelling and it's brilliant.much smoother ride ,not that it was bad before,and it's onto pitch press one button and levelled(y).
Brian & Jo
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
No. It depends what you want. If you want rock steady levelling on rough ground, you’ll need hydraulic rams. Air suspension addresses the ride, first, and then a degree of levelling.
I have had both and, if I could afford the weight, I’d get both again. Air suspension levelling will cope with a decent sideways slope and modest amount fore/aft, but certainly enough to level-off most camp site pitches. It can help avoid catching your rear end on a steep ramp and will aid waste water dumping.
Hydraulic rams will provide much greater level adjustment and tank emptying. The van is also rock solid when the jacks are deployed. Jacks can make wheel changing (or rotation) an easy task and can be an added security measure.
So, although you can do more with air suspension, hydraulic rams are much better for levelling.
jdk62
Aug 19, 2014
1,855
5,564
Cliftonville
A Class Burstner
Since 2014
Thanks - very helpful. So I guess both add quite a bit of weight?
Feb 24, 2013
13,079
101,442
Bolsover, Derbyshire
Hymer S800
not long enough
Expensive?
Oh yes, ÂŁ10K for both
we have the E + P jacks and air suspension (think it is VB), the 2 are interlinked so the air is dumped before the jacks are deployed, only works with fully auto air suspension which on a Mercedes can only be fitted to the rear axle
jdk62
Aug 19, 2014
1,855
5,564
Cliftonville
A Class Burstner
Since 2014
Blimey.....o_O
I live in Oxfordshire - does anybody know of local specialists who can supply & fit?
funflair
19,339
30,205
Guisborough
MORELO palace
since 2012
Blimey.....o_O
It's not far to SAP at Doncaster.
Martin
Apr 9, 2014
1,307
6,596
Lincs
Conrad Anderson in Birmingham are your nearest E &P dealer. We went to Blackburn as the deal offered was much better. Just went for hydraulics.
laird of Dunstan
1,464
3,953
lincolnshire
Rapido 9000DFH
ex caravanner
The jacks are great,no more wet and dirty knees crawling around fitting blocks or cranking down the legs ,one button and done
jdk62
Aug 19, 2014
1,855
5,564
Cliftonville
A Class Burstner
Since 2014
Thanks for all the advice and feedback.
Our motorhome is back at the manufacturers getting some faults sorted in the factory, so when we get it back I think I will go for both.
I guess like most things, pays to shop around even if it means a bit more travelling.
Can it all be done in a day?
R
Robert Clark
It takes about 2-3 days for both jobs.
The people who did my E&P levellers also fitted the VB air suspension.
R
Robert Clark
Robert - who did yours?
http://www.rosmia.co.uk/
They're based in Sussex, but if you look on the VB air suspension site or the E&P levellers site, you'll find a list of local installers
http://www.vbairsuspension.co.uk/en/
http://www.ep-hydraulicsnews.co.uk/
VB and E&P are the two systems commonly used by the motorhome manufacturers, and actually link together, so that when you use the levelling jacks, the air suspension lowers itself automatically.
jdk62
Aug 19, 2014
1,855
5,564
Cliftonville
A Class Burstner
Since 2014
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
I also rate Goldshmidt (try Travelworld in Telford)
One thing I found with jacks was that the vehicle often ended up rather high off the ground. You may need an extra step.
funflair
19,339
30,205
Guisborough
MORELO palace
since 2012
The automatic level function always ends up with the van higher than if you do it in manual mode, regarding Goldschmitt I believe they are a little more complicated than E&P and require more regular servicing, we were told this at the Goldschmidt centre at Polch.
Martin
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
We have recently had both rear air assist and HPC hydraulic levelling fitted by http://www.as-airsuspension.co.uk/index.html up in Warrington and very pleased with the setup.
This is our third moho to which we have had AS fit their air susspension system and very happy to recommend them for the products and their service.
Kevan
1,097
968
Kent and south west France
van conversion
30 years caravan/motorhome
I agree, AS systems are very good and nice people to deal with as well(y)
canopus
6,139
10,255
rural Lincolnshire
Carado CV640 Pro
Since 2010
Another thumbs up as Martin said for SAP in Doncater - he puts things right that others, including names mentioned in this thread, have done wrong or shoddily. Mick at SAP is E&P's UK troubleshooter.
Imbiber
270
185
Castleford, West Yorkshire
Another +1 here for Mick at SAP in Doncaster. He is a top man and his engineering skills are perfect for the job in hand. He will go the extra mile in making sure the products work and is clearly not one to be beaten by jobs others refuse to undertake.
We have both the full VB Air (on six wheels) and the E& P levelling and would throughly recommend them.
We elected for air to improve the ride quality and travel comfort for our rear passengers and this has made a tremendous difference for them. It is fantastic for maintaining a level ride height even when fully laden and the overall ride comfort is vastly improved.
The E&P is without doubt the best addition you could ever wish to invest in for a motorhome and if I were to choose one over the other it would be E&P every time.
jdk62
Aug 19, 2014
1,855
5,564
Cliftonville
A Class Burstner
Since 2014
Appreciate the feedback. - thanks
Jun 10, 2010
8,507
20,218
Shrewsbury (sometimes)
N&B Clou Liner MAN
We were not impressed with the service we got last year from Conrad Anderson.
The workshop was incredibly messy, I didnt feel confidence in the guys doing the work (I have since had to reassemble some of it myself) And they charged more than they said.
Ive been happy with previous work but feel that they have changed and will not be going back.
Jon
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
I have VB 4 channel and EP jacks factory installed. Air levelling is limited to the size of the bags but for short stops on fairly level ground they are great. The jacks are tops for almost any situation and I have some interlocking pads which give me extended lift and or reduced strut extension. Although mine were a factory installed option Mick at SAP has been my go to man for issues, even EP UK will refer you to him for technical queries. The only money he has made from me is the purchase of a remote control for the EP system but he always takes my calls and spends time explaining solutions.
Chipster
1,008
1,120
East Midlands
Getting there!
What sort of weights are we looking at for E&P and VB full air? Getting curious :)
