Air Suspension Advice (1 Viewer)
ukbill
5,501
5,274
Pinoso
4 berth low profile
starting on saturday 10/3/2012
sorry john i didnt mean as, as in the company but the air suspension and you answered that anyway lol thax
Sep 9, 2014
168
102
Coach built
Summer 2014
AS is something I've been pondering for a while.
A bit concerned about grounding the rear of the motorhome, especially for things like ferries...I 've got an Autotrail Dakota with a tow bar and I don't seem to have a lot of clearance between it and road.
So;
if I fit a system how much could I expect to be able to raise back end for the times I may need to?
Indeed can the back end be raised at all with these systems or are they purely comfort orientated?
So far all the photo's I've seen show the bags fitted to m'homes with leaf springs...I've got a torsion spring Alko axle. Are kits available for these on DIY fit basis?
Thanks!
MikeD
3,936
3,697
London
IH PVC
Since 2012
Getting mine fitted at Dave Newall on the 11th of this month Dunlop Kit fitted to a Fiat Maxi chassis on a Dethleffs globetrotter. I am looking for a big improvement in the ride and handling.
Dave fitted mine and did a great job. The difference will be immediately noticeable especially on the motorway.
Best money I have ever spent on my motorhome (y):)
MikeD
3,936
3,697
London
IH PVC
Since 2012
So;
Thanks!
We fitted ours because the back end of our Autotrail kept hitting the floor. Not sure how much lift they have but enough to get back to original ride height in our case and a bit more to level van on site if needed.
Don't know about alko we have a Fiat chassis
SandT
127
383
Malta
Safari Trek
Newbie
I was worried that my insurance would consider this a modification, so phoned them beforehand. They said that provided it was fitted by a recognised trades-person, there would be no excess. I asked if Watling Engineering would qualify and they said Ok!
I was recently weighed and told that because I had air suspension the 30kg overweight on my rear axle would not be a problem if I fitted tyres with a wider profile.
NOTE: Air Springs do not increase the load carrying capacity of your vehicle, they only improve driving and handling characteristics when carrying a load or towing. Never exceed your vehicle’s Gross Vehicle Weight Rating (GVWR).
Terry
Lenny HB
53,309
149,501
On the coast in West Sussex
Hymer B678 DL
Terry
Not so, depends on the chassis, my Al-Ko chassis has a rear axle limit of 2000Kg, both Hymer and SV Tech have confirmed that it can be increased to 2240kg by fitting air assist springs.
5,920
38,675
Uk
I will be interested in your out come and look forward to a report regarding ride quality after having them fitted.
SandT
127
383
Malta
Safari Trek
Newbie
The gross vehicle weight rating (GVWR), or gross vehicle mass (GVM) is the maximum operating weight/mass of a vehicle as specified by the manufacturer including the vehicle's chassis, body, engine, engine fluids, fuel, accessories, driver, passengers and cargo but excluding that of any trailers.
Not talking about individual axles but the GVWR.
Terry
Jul 23, 2012
80
82
Kingswinford & 86230
Burstner Elegance 890
Since 2012
Fitted Dunlops system(via Marcel Leisure) over Easter to to my Burstner Tag axle. Having looked and studied the instructions over the previous few weeks- thought it would take me about an hour to fit each set of brackets and air bag -WRONG!
I discovered that I had to drill the chassis to mount the 'fixed' brackets, as only one of the four holes need to mount the bracket are actually there, there is a cross member in the way, the mounting bolts of which are in the way of the mounting holes for the new bracket, the brake line tee piece bolt had to be drilled & tapped into the new brackets otherwise it might foul the air bag.
Fitting the 'moving' bracket & air bag took about 30 mins, connect up the air pipes I had previously fitted, job done
Very pleased with end result, but not a quick job to do
Aug 18, 2014
23,740
133,194
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
if you are in a rtc and the plods find it was down to a diy air suspension you will not be covered by your insurance and the money you saved my cost dear hope this help get it fitted by a trades person ray
AS Jaws has said that isn't correct.
Terry
& you won't be prosecuted if the axles aren't over & the GVM is.
Abacist
3,711
10,547
Devon
N & B Arto 88F Tag
since 2013
Terry
This is quite wrong! SV Tech have increased my GVWR by the fitting of Dunlop air suspension. It also increased the weight rating of the rear axle and the weight rating of the front axle remained unchanged. I suspect that it is all down to each individual make/model of motorhome and the chassis that it is on as to what can be achieved. But to state that the overall gross weight cannot be improved by fitting air suspension is quite wrong for most vans I suspect!
Minxy
32,623
66,460
E Yorks
Carthago Compactline
We have had AS fitted air suspension assistance systems fitted to the rear axle of 2 of our previous MHs and certainly if we had a coach-built again we'd be making a b-line for them to fit it! It makes a heck of a difference not only to the comfort but especially the handling, it turns a wallowing whale into a sleek shark by comparison!
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
Quite right. I went to SvTech to uprate my van to 3700kg and was told that if I wanted to up the payload more ( up to 4250kg) I would need new tyres and rear air suspension.
So, it can be done, as long as the chassis is suitable
Allan
SandT
127
383
Malta
Safari Trek
Newbie
I don't understand how can someone come along and alter the chassis Manufacturers maximum operating weight just by fitting an aftermarket item ?
Terry
Abacist
3,711
10,547
Devon
N & B Arto 88F Tag
since 2013
The manufacturers use the same chassis for different vehicles so they are not always plated at their maximum
E.g. Some down plate to keep within the 3500kgs limit for some drivers licences.
Nov 4, 2011
5,920
38,675
Uk
Any feed back yet on your new air bags?
Aug 27, 2014
1,910
3,880
Shropshire
McLouis Tandy 640+
Since 2014
So;
Thanks!
Not a direct comparison, but on a leaf-sprung Ducato X244 with the Maxi chassis, my air suspension raises the back end by about 2 and a half inches when fully inflated. Definitely helps, and the extra clearance provided a bit of reassurance when going on and off some Scottish ferries a few weeks ago! I run mine at 60psi (100psi is the maximum) and it keeps the back end about 2" higher than without.
The biggest improvement though is the handling - still no sports car, but it doesn't roll nearly as much when cornering, and straight line stability is vastly improved - very noticeable when passing trucks on the motorway, my van isn't pulled off line by the air passing around the truck nearly as much as was happening pre-air suspension.
homercostello
232
209
kidsgrove staffs
9 years
Hi had the Dunlop air suspension fitted yesterday and can say already that the motorhome feels a lot more taut if that is the correct word to use. At three metres high it wallowed around roundabouts and now feels like its on rails. The motorhome has risen one and a half inches at the rear wheel arch pumped up to thirty pounds pressure, there is scope for more adjustment so I will have to have a play. If any one is considering getting it fitted I would say you will not be disappointed.(y)
Aug 27, 2014
1,910
3,880
Shropshire
McLouis Tandy 640+
Since 2014
I fitted a Dunlop system from Marcle and really easy job. Had the one with single pump up valve with gauge and two switches. Open both n/s and o/s switch, pump up on level ground then knock both switches off, both air bags same pressure both sides.
Opposing air bags (as in n/s & o/s) should NEVER be pneumatically joined. Not only can it seriously effect on the roll (side to side), it can cause SERIOUS body weave once it gets going.
:eek:
Brian, get it separated - please.(y)
Hope it helps.
Trikeman.;)
That could be a picture of the install I did on my van, it's identical! The Dunlop kit from Marcle Leisure I found was very easy to fit myself, the quality of the gauge assembly is good, and I carry a cheap 12v compressor if I want to change the air pressure when out & about. Red for Right and errr, bLue for Left.......
Trikeman, I think you need some air in yours and the valves closing to get the full effect..... ;):whistle:
