Air Suspension Advice
Discussion in 'Motorhome Chat' started by wiljoy, May 3, 2015.
  1. wiljoy
    wiljoy Funster
    May 23, 2008
    919
    999
    Crook, Durham
    On our first long European tour in the new van. As I'm well within my load capacities for the rear axle the van is noticeably lower. When I return back to the UK I intend to have the rear fitted with air bags to help the suspension. It is many years since I had these fitted on a motor home and units change. Can anyone recommend a pair of quality units for DIY ibstall
  2. Allanm
    Allanm Funster
    Jun 30, 2013
    3,256
    4,423
    Cotes d'armor, France
    This is something I will be doing in a couple of weeks, I'll be interested to see what kit is recommended.
    Allan
  3. hilldweller
    Dec 5, 2008
    27,769
    26,857
    Macclesfield
    • Like it Like it x 2
    • Useful Useful x 1
  4. PenelopePitstop
    PenelopePitstop Funster Life Member
    Sep 3, 2007
    2,489
    1,357
    Royston Vasey and beyond!
    We had ours fitted by AS AirSuspension - both in this van and our previous one - excellent system and excellent work by Phil Berry at AS!
    • Like it Like it x 3
  5. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,812
    1,030
    Cark, Cumbria
  6. DP_JAY
    Mar 17, 2010
    1,812
    1,030
    Cark, Cumbria
    • Like it Like it x 1
  7. jemhorn
    jemhorn Funster
    Nov 13, 2013
    407
    377
    Bideford, Devon
    Dunlop system on previous van, new having Dunlop fitted to ALKo chassis by Phil from Rhino Installs in June. Phil doesn't travel as far now so having it fitted when we are in York
  8. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,899
    23,625
    Narrfoook
    I fitted mine .. Done it in the road outside the house with snow on tghe ground ! Total fit time less than 45 minutes from memory
  9. JJ
    JJ Funster
    May 1, 2008
    15,019
    27,019
    Airbag assisted rear suspension... very, very highly recommended.
    JJ :cool:
  10. davejmobile
    davejmobile Funster
    Mar 13, 2010
    98
    33
    Hi i used there units fro AS air suspension fitted my self no problem
  11. Manic
    Manic Funster
    Nov 4, 2011
    1,094
    1,198
    Uk
  12. hilldweller
    Dec 5, 2008
    27,769
    26,857
    Macclesfield
    No, there is a "Tee" joint underneath. This guy makes them in Poland I'm sure he'd sell and extra gauge for little money.
    You can ask on 07921128933, his wife runs the business in UK from St Helens, I collected from there, really nice helpful person.
    In theory I prefer the T as if there is a failure both sides go down.
  13. Jaws
    Sep 26, 2008
    18,899
    23,625
    Narrfoook
    Mine were done individually as standard.. In fact the control panels as bought from AS have two buttons on .. one for each side
    Note.. While control panel and wee on board 12v compressor is nice to have, I used the simpler option of tucking the ends in the gas locker and using an air line for the first year we had them.. It was only after I decided to get all posh I bought the control panel and a 12v tyre compressor from halfrauds and fitted that..
  14. Judge Mental
    Judge Mental Funster Deceased RIP
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    I fitted drive rite myself years ago on a few vans..bought it from Dublin head office as cheaper (No surprises there!:censored:)
    just run separate air lines.....I always went for cheap basic kit as bags small and can be pumped up with a foot pump and checked with a tyre gauge
  15. DP_JAY
    Mar 17, 2010
    1,812
    1,030
    Cark, Cumbria
    The two sides tee'd togother is a bad idea, it wil encourage the thing to roll over on corners, as I discovered. As the weight starts to shift it forces the air out of the "loaded" side & into the "unloaded" side which exagerates the body roll. I would go as far as to say it's dangerous.
    My system has one inflation point & guage, plus a pair of valves to select which side to inflate/deflate.
    I made the mistake of leaving the valves open once, Never again!
  16. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    5,660
    10,792
    Lorca,Murcia,Spain
    Oh to be able to do things like this again ! :(
  17. hilldweller
    Dec 5, 2008
    27,769
    26,857
    Macclesfield
    I hadn't thought of that. Easily solved with a restrictor in one line.
  18. mentaliss
    mentaliss
    Nov 2, 2012
    657
    308
    Lancing
    Dunlop don't recommend a 'T' off system, each air bellows should have their own air line back to the air gauge/s this way you can adjust the air pressure to each bellows to compensate for weight distribution and road unevenness..
  19. Trikeman
    Trikeman Read Only Funster
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    I fitted a Dunlop system from Marcle and really easy job. Had the one with single pump up valve with gauge and two switches. Open both n/s and o/s switch, pump up on level ground then knock both switches off, both air bags same pressure both sides.
    Opposing air bags (as in n/s & o/s) should NEVER be pneumatically joined. Not only can it seriously effect on the roll (side to side), it can cause SERIOUS body weave once it gets going.
    :eek:
    Brian, get it separated - please.(y)
    [​IMG]
    Hope it helps.
    Trikeman.;)
  20. rosalan
    rosalan Funster
    Jul 12, 2013
    916
    770
    Beds
    I was worried that my insurance would consider this a modification, so phoned them beforehand. They said that provided it was fitted by a recognised trades-person, there would be no excess. I asked if Watling Engineering would qualify and they said Ok!
    I was recently weighed and told that because I had air suspension the 30kg overweight on my rear axle would not be a problem if I fitted tyres with a wider profile.
