Air ride suspension
Discussion in 'Tech/Mech General' started by paddiesdad, Nov 13, 2009.
  1. paddiesdad
    paddiesdad Read Only Funster
    Apr 30, 2008
    4
    Hi all,
    I have a 1999 Hymer A Class motorhome which I generally find very good, except for the ride. This is rather harsh over all but the smoothest of roads and the body roll on roundabouts or cornering alarms my better half.
    This all seems to scream out for air ride suspension, but before I go to the £400 + expense of installing the system, could anyone tell me if they've had such a problem and has air ride helped?
    Cheers m'dears.
    Peter:Smile:
  2. dellwood33
    dellwood33 Read Only Funster
    Apr 25, 2009
    3,449
    887
    Newcastle
    I had air suspension aids fitted to the rear leaf springs of my MH at theShepton Mallet show earlier this year. Simple installation (foe them) with a gauge and air fill/deflate point at the drivers step. This allows a certain amount of "Levelling" on site by adjustment of the air in either side if required.
    I have seen improvements in the ride, both on cornering and on the motorways etc, where the van is no longer deflected by large vehicles coming past.
    Certailnly was a worthwhile investment from my point of view. :Smile:
  3. dragabed
    dragabed Read Only Funster
    Apr 15, 2009
    63
    hi peter
    best 400 you will ever spend increaces road holding and improves cornering and you can use it to level the van on site.i use mine set at 35psi and carry a cheap tyre inflator to add or take out air and control left and right lift. it must add to your tyre life aswell
    colin
  4. JayDee
    JayDee Funster
    Oct 7, 2007
    1,312
    167
    N. Devon
    Concur with both of these. An immense improvement. We used GB Services in Honiton.
    John
  5. stagman
    stagman Deleted User
    Hi if you can DIY it is simple ,and you dont need the compressor , then check out Driverite website you should get all the kit delivered for just over £300.:thumb:
  6. meggie
    meggie Funster
    Jan 12, 2009
    199
    412
    milford haven
    i had it fitted at shepton by air ride on my roasatar 780 great improvement,
    i carry a scooter on the back which i can add more air to levellthe van
    money well spend:thumb:
  7. ronald4874
    ronald4874 Read Only Funster
    Oct 31, 2008
    177
    3
    Poole Dorset
    Air Rides
    Yes air rides are a great improvement to any van. I had air rides fitted about 9 years ago due to the need to carry a scooter on the rear, I find 40 psi does a good job and tends to force the front downwards on account of increased rear height.
    My van is a CB with bed at the front which was removed and a storage area established to increase load on the front axle. After a number of goes of distributing the load I was able to get both axles in tune, with many weigh bridge tickets to prove.
    Having looked at new vans a high proportion are low profiles and like the A Class have no loading facilities at the sharp end, so the carrying of a scooter on the rear would appear to me to be impossible.
    Ron
  8. wiljoy
    wiljoy Funster
    May 23, 2008
    899
    984
    Crook, Durham
    Hi, I had the same problem on my van and at 4.5 ton the standard suspension was struggling.
    After experiencing the bolt on air bags dropping off I was reluctant to fit them again. Some long thinking and research saw me having AS Suspension Services at Warrington fit a full kit. Not cheap but a very good job and I am extremely satisfied. At last a reliable company, excellent service and the product does the job with an amazing difference to roadholding and cornering. The ride quality is now how it should have been if the manufacturers could build them properly.
    Wiljoy:thumb:
