Air levelling suspension
Discussion in 'Motorhome Chat' started by Steveonley, Jul 1, 2014.
  1. Steveonley
    Steveonley
    May 14, 2014
    19
    3
    Bromsgrove
    Thinking of getting this fitted to our Swift Sundance Motorhome as Carol does not like using ramps. Does anyone know if these are any good, the cost or how much it would add to our ever increasing payload ?
  2. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,366
    14,497
    Bolsover, Derbyshire
    we have air suspension, a fairly basic system, but do not confuse this with self levelling, which may need hydraulic rams, a completely different package
    we certainly still need ramps
  3. Bailey58
    Bailey58 Funster Life Member
    Jun 23, 2010
    6,749
    10,464
    Norfolk and Toftir.
    It's late so can't look now but when I asked Kath and Phil of AS Air Suspension at Peterborough the all four corner jobs were thousands as they were at the NEC about six years ago from somebody else. :(
  4. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    13,017
    40,304
    We have this Full Air = www.vbairsuspension.co.uk
    On our tag axle... fantastic bit of kit... normal levelling is great, just press the "Auto Level" on the compter thingy, and it just levels it`self ..
    But if the ground is very up hilly you will still need blocks. it has it`s limitations.. :(
    Front nearly on the ground and lift the rear to it`s exstreem`s is approx 14 - 16 inches.
    It does what it says on the label, and is a superb comfortable ride even on rough roads, up to a point..
    Not cheap, in fact bloody expensive.. it was fitted when we bought the motorhome.. (y)
    Would I have it put on.... I`m not sure.. because of the expense.. but maybe.. :rolleyes:
    Not much of the original suspension, with the full air system is left on.. it`s all ripped off/out and replaced with the same as what lorries have... and it has it`s own on board compressor..
  5. Daifuse
    Daifuse
    Feb 20, 2013
    184
    310
    Milford Haven
    As far as self-leveling is concerned, who remembers the Jack-All system fitted to cars pre-war? My first car, a '38 Morris 12 had this fitted. It comprised 4 hydraulic legs, on on each corner (attached to the axle beams) and a hand operated pump in the passenger footwell. A 4 way selector enabled you to jack up whichever corner you wanted - or all 4 if needed - so you could change a wheel without having to jack the vehicle up by conventional means. Surely, some enterprising person could come up with a similar idea for motorhomes. It shouldn't be that expensive to manufacture or difficult to fit.
