Hi, this is our first posting! We have a Elnagh Baron, Fiat Duccato cab! The air bag warning light is on and the horn does not work! Has anyone had the same problem!
Hi I don't know about the horn but it is quite possible that it is the passenger seat being moved which has caused the connections under the seat for the air bag to have a bad contact. Check the connector also check the drivers one. This is very common in cars. It is also possible that the horn and air bag may use the same fuse.
Lin
