Air Assisted Suspension Query
Discussion in 'Tech/Mech General' started by Fran the van, May 15, 2015.
  1. Fran the van
    Fran the van Read Only Funster
    May 15, 2015
    Newport, South Wales
    I have a 2000 Niesmann+Bischoff Arto 69 with an Airide system fitted. The vehicle has a slight lean to the right so I suspect that side needs more air: however I have no information on what needs to be done. There is a pressure gauge, valve and separate red and blue lines with 'taps' fitted just inside the doorway. Hopefully a picture is attached.
    Is anyone familiar with this type of installation and what needs to be done. The gauge currently indicates about 45psi/3.2bar - there is only one needle.
    Many thanks for any assistance.
  2. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,637
    3,189
    Cumbria
    Move the red valve into the down position and note the reading then shut the valve off again, do the same with the blue valve and compare the readings. Whichever is the lessor, open that valve and fit a pump or a compressor to the valve inlet after removing the metal valve cap and fill to equal pressure as the other side. (y)
  3. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,355
    9,798
    hopefully its just uneven on the airbags but a pronounced list also indicates a torsion bar suspension spring may have failed on an alko chassis
