Can anyone competent/knowledgeable in battery connections/ usage advise if this is an acceptable set of connections.
Connecting a battery master from a 100AH agm leisure battery that is charged from a 100 Watt solar to a 110Ah sealed battery ( none agm) in order to top up the 110 ah sealed battery to run a microwave or similar appliance through an inverter connected to the 110ah battery for short periods.
Additionally would it also be possible to fit a further battery master from the 110AH sealed battery to the engine start battery which would then charge up when both leisure batteries are full.
thanks
thanks
