Aftermarket daytime running lights
Discussion in 'Peugeot' started by benellioldman1, May 17, 2016.
  1. benellioldman1
    benellioldman1 Funster
    Apr 29, 2014
    44
    31
    isle of man
    Ref Peugot Boxer 2.2 2005 I was wondering how easy it is to fit and wire up daytime running lights (the ones on ebay that says fits into spotlight apertures) under the bumper. The van has just got blank discs there at the moment. Things like pre wiring for the spots (if present) would that set up help me wire in the lights and how would i need to wire into the dash controls because they would need to be independent to the main lights. It would be good if the would slot in with wiring upto a rocker switch on the dash. Has anyone fitted these I a would appreciate your help
    Steve
  2. sdc77
    sdc77 Funster
    Jan 28, 2013
    2,643
    3,152
    East london
    • Like Like x 1
  3. andy63
    andy63 Funster
    Jan 19, 2014
    2,077
    7,881
    south shields
    Hi Steve. . Fitted some to a transit ..same idea .. designed to go where the fog lights would have been...
    Think they came from led .com or something like that...
    The instructions were fairly good.. you won't need dash switches or the existing fog light wiring...
    Think it was just an ignition feed and feed from side or head lights to dim them when you switch on your normal lights..
    They must have some voltage sensing device which detects when engine is running and alternator is charging... That's what turns them on...
    Only possible issue on a mh is the lights coming on when you go on hook up when your battery charger lifts the voltage...
    I has to wire mine to an engine run signal for similar sort of reason as mine came on when my diesel heater kicked in...:LOL:..
    But fitting normally straight fwd and we'll covered in the instructions...
    Ta andy.
    • Useful Useful x 1
  4. benellioldman1
    Apr 29, 2014
    44
    31
    isle of man
    Thanks for your reply,did you fit them yourself and was it fairly easy i am no electrician but can follow simple instructions
  5. benellioldman1
    Apr 29, 2014
    44
    31
    isle of man
    Thanks Andy
    You were posting just before my last question. I presume from what you have said the daytime driving lights do come on independently without the other lights being illuminated, the very reason i want them is for continental driving and lesson the chance of replacing headlight bulbs etc.
  6. Cavs
    Cavs Funster
    Apr 10, 2010
    250
    249
    Bedfordshire
    Aftermarket DRL by Ring do indeed work on the voltage changes when the vehicle is started. They do not come on when on hookup - I asked Ring specifically about this before buying them and they gave a technical explanation about why not. (And they were right!)
    The wiring for these is all under the bonnet, providing you can find a live feed - I used the positive jump start terminal near the fuse box. The other wires go to earth and one of the lighting feeds behind the headlight for dimming purposes.
  7. andy63
    andy63 Funster
    Jan 19, 2014
    2,077
    7,881
    south shields
    If they are like the ones I fitted then they will come on if wired into any circuit that the charger raises the voltage on when hooked up...
    Didn't go into detail but mine were initially wired in to a ignition circuit. I engine plumbed my diesel heater (a hydronic ) and wired the vehicle fan to turn on if I left the fan switch turned on... When the heater started and fan cut in my my Drl's also turned on.. so it can happen...On some types...
    I've seen it mentioned in the fitting instructions on some aftermarket kits as well.
    Andy
  8. andy63
    andy63 Funster
    Jan 19, 2014
    2,077
    7,881
    south shields
    Yes that's how mine work.. little black box on mine with 3 wires.. The earth,a live feed ,and another feed from the lighting circuit ,in my case the side lights,to dim them when you use your normal lighting..
    Andy.
  9. Cavs
    Cavs Funster
    Apr 10, 2010
    250
    249
    Bedfordshire
    Fair enough, probably a slightly different process/set up. The Ring techie said that theirs senses the voltage drop when the starter kicks in followed by the higher voltage generated by the alternator kicks the lights into life and keeps them on. They sometimes come on briefly when the ignition is switched on, but then go out. They have never come on with the mains hookup connected or the solar charging.
    I suggest the OP asks the helpdesk for whatever he's thinking of buying, or use an ignition feed instead of a permanent live.
  10. sdc77
    sdc77 Funster
    Jan 28, 2013
    2,643
    3,152
    East london
    As far as the ledcom ones go.. they come with full instructions and pictures showing exactly what to connect to. Effortless
    • Like Like x 1
  11. benellioldman1
    Apr 29, 2014
    44
    31
    isle of man
    Thanks everyone for your suggestions a great help
    Steve
  12. MH 55 FUN
    MH 55 FUN Funster
    Feb 18, 2016
    2,138
    3,294
    Rural South West Wales.
    We have the ledcom D.R.L.'s too & as others have stated - no issues fitting or working.
