AES fridge autochangeover (1 Viewer)
weebill
65
84
aberdeen
Coach built
since 2006
An interesting incident when on the aire at Honfluer which has 5amp mains supply.
My fridge, being set to auto, connected to the mains and ran for a while but when I switched the electric heating on the fridge changed to gas supply and when the heating was off the fridge reverted to mains.
Having since been on a site with 10amp supply and no problems I assume it had something to do with voltage drop but would appreciate any ideas.
Bill
MC 55 FUN
3,432
6,347
Rural South West Wales.
2015 Majestic 195
Since 20th Feb' 2016
Likely to be overload,what is the wattage consumption of your heater & fridge ?
5a @230v will only produce circa 1.15kw
10a @230v will produce circa 2.3kw
weebill
weebill
65
84
aberdeen
Coach built
since 2006
Thanks for the quick responses.
Definitely seems to have been due to overloading the 5a supply as it's never happened before or since.
Bill
weebill
weebill
65
84
aberdeen
Coach built
since 2006
Sorry, should have said that I had the heating on the 1kw setting so I'm guessing the fridge won't function on mains with only 0.15kw left
Lenny HB
53,421
149,948
On the coast in West Sussex
Hymer B678 DL
That will not have any effect the oly thing that will happen if yopu overload the supply is the MCB will trip.
weebill
weebill
65
84
aberdeen
Coach built
since 2006
Hi Lenny, so there must have been a volt drop not relating to the 5a supply ?
Feb 24, 2013
13,083
101,447
Bolsover, Derbyshire
Hymer S800
not long enough
still a very brave thing to do, even your battery charger or almost anything else plugged into a socket could have been enough to tip over the 5A, then you have all the hassle of finding someone to reset it
I suspect their intention with restricting the Amps to 5 is to stop electric heating being used
Good spot though to see it change to gas, did you hear it ignite?
weebill
weebill
65
84
aberdeen
Coach built
since 2006
Exactly that David. Heard the gas ignitor clicking and checked the lights on the fridge panel.
