Aerials and TV's (1 Viewer)
Uschi
Ipswich
4 months
We have just purchased a Swift Suntor and getting rid of a few teething problems we are really happy with Foxy (her name). However, we are still not able to solve an aerial problem. The new TV works brilliantly connected the House areal, but despite a new amplifier, is not working well with the Status 530 directional area installed on top of Foxy. We get analogue pictures but not digitial channels. We live in Ipswich in Suffolk. We have asked just about everybodyy, but can't find any decent advice either from caravan/motorhome dealers of areal specialists. Help pretty please?:Sad::Sad::Sad:
mick noe
Apr 14, 2009
638
539
near Boston Lincolnshire
low line
more info please:Smile: what happens when you scan for channels on your digi box ? does it give any on screen message? must say omni directional arials not much cop in my experience:Sad:
GuitarDave
17
Kent
Since 2009
Signal problem
I'm not sure where you are located in Suffolk when you try and use the motorvan aerial.
There are some areas that I have visited that require a vertically polarised antenna i.e a normal house aerial turned 90 degrees sideways. It is sometimes necessary to invest in a cheap outdoor aerial and mount it on a pole just to get a good picture, You would not get a digital signal strong enough in some places with the Status caravan unit.
It all comes down to signal strength in the end:thumb:
43,295
49,268
it may be you arent pointing directly at (or very near directly) the transmitter.
anologue signal is pretty broad and the aerial only needs to point roughly in the correct direction to get a picture, but a digi signal is much narrower and fairly accurate pointing is needed.
also.....is the aerial set to the correct 'plane'...vertical or horizontal...try turning the bottom handle to the other 'plane' then try tuning again.
tune to a weak anologue channel then tune that, by moving the aerial, to the best possible reception.....then tune digital.
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
:welcome: The tv dose have a digital tuner yes, cos yours truly was trying to tune in a none digital tv for about a week before I twigged:Blush::roflmto:
43,295
49,268
the status 530 is a directional aerial mick....you're thinking of the 305 'flying saucer'
Terry
11,926
9,033
Lincolnshire
Can't remember ;)
Hi Uschi and welcome :thumb:
start from scratch- look at the direction the ariels point on nearby houses and point your in that direction,make sure the amplifier is turned on and all the cables conected :thumb: then check they are into the tv/freeview box :thumb:If alls well do a first time instaltion :thumb:
If that does not work get back to us ::bigsmile:
terry
