aerial advice please
Discussion in 'TV & Satellite' started by roky1983, Feb 28, 2011.
  1. roky1983
    roky1983 Read Only Funster
    Jun 9, 2010
    46
    25
    wales carmarthenshire
    im looking for an aeriel for my van sumfin easy to use and to set up, would need to be transferable as i change my van often, i bought a flat 1 from argos it plugs in but it dont even recognise it, im in a wheelchair and cant walk at all so please bear this in mind
    thnx all
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,421
    5,449
    East Sussex 01-580-881288
    I have been selling a lot of these and not had a complaint.
    Avtex STH1000 Digital Aerial <<
    Designed for caravans and motorhomes the new Avtex STH1000 Digital antenna is light weight compact and very easy to use.
    With its unique flexible mounting system the STH1000 can be installed indoors or outdoors in seconds.
    The STH1000 has an integrated 20db amplifier which can be powered by the antenna power out function found on most set top boxes and all Avtex digital televisions.
    Alternatively you can use the 12volt dc power inverter included.
    Enjoy crystal clear digital reception with the STH1000 complete antenna solution.
    The compact Avtex STH1000 simply uses its suction mount to attach to a nearby internal or external window or other flat surface.
    Internal or external mounting using the supplied suction mount, or for a more permanent solution, use the pole mount which is also supplied in the box.
    Peter
  3. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    Here is a foto of my setup, I find the directional antenna better that the omnidirectional type, also the whole setup is removed off the van in a few minutes.
    http://www.motorhomefun.co.uk/attac...889-internet-access-while-europe-100_2785.jpg
    Doug...
  4. hilldweller
    Dec 5, 2008
    27,771
    26,861
    Macclesfield
    Have you ever clarified if they are suitable for vehicle "12v" ? Just to be on the safe side.
