Advice required
Discussion in 'Motorhome Chat' started by ruraldriver, Feb 15, 2011.
  1. ruraldriver
    ruraldriver Read Only Funster
    Aug 25, 2010
    11
    Cheshire
    Hi all, I have a compass calypso on a 1996 Fiat Ducato base & I am now having very serious dificulty selecting gears. The gear leaver will not go into the gear required. I've tried double the clutch etc but to no avail, I have even had to pull away in 3rd. When sellecting reverse the the gear grates prior to selection. Any serious advioce, background or informatiom would be gratefully received.
  2. JJ
    JJ Funster
    May 1, 2008
    14,888
    26,701
    Hi and welcome..
    Can you select gears when the engine is not running?
    When you try to select gears with the engine running (other than reverse) does it "grind" then?
    JJ
  3. ruraldriver
    Aug 25, 2010
    11
    Cheshire
    Hi JJ,
    Just been out & tried this.Yes I can select all forward gears when engine not running. Started her up & unable to select forward gears. Does this point to the clutch adjustment??
  4. JJ
    JJ Funster
    May 1, 2008
    14,888
    26,701
    Has this suddenly happened or has it got worse over time?
    At the moment I strongly suspect clutch trouble of some sort...
    Does it make any strange noises when you depress the clutch pedal?
    Has the van been standing over winter?
    JJ
  5. ruraldriver
    Aug 25, 2010
    11
    Cheshire
    Hi again JJ, There does not seem to be any different noises coming from depressing the clutch but this problem has been creeping up. I use the van 4 times a week to & from work about 42 mile round trip.
    Bernie
  6. JJ
    JJ Funster
    May 1, 2008
    14,888
    26,701
    Hi Bernie... there will be Funsters who know much, much more about these things than me (and I am sure they will be along to advise soon) but I would guess a wearing clutch or stretching cable (if it has one.)
    If you can adjust these things these days it would be the best (and cheapest) place to start...
    JJ
  7. ruraldriver
    Aug 25, 2010
    11
    Cheshire
    Cheers JJ, You are right Cheyne has sent me a private message so people are passing on their knowledge. BUT thanks for your quick response, I owe you a pint!
    Thanks again, Bernie
  8. wolly
    wolly Read Only Funster
    Aug 16, 2010
    20
    ripon n yorkshire
    wolly north yorkshire
    if you look on top of gearbox you will see two cables they go on to a bush and water from windowscreen runs down on to the top of cables and they tend to seizup.it is a easy job to free it get some one to sit in van and move gearleaver in to gears no need to have engine running.my citreon did the same as you say your van is dowing.where the pipe runs on top of the gearbox i exstended my pipes so the water runs away from the cables hope this helps.also put plentey of grease on top of cables when done.
  9. ruraldriver
    Aug 25, 2010
    11
    Cheshire
    Cheers Wooly will try first thing tomorrow. Bernie
  10. pheasantplucker
    pheasantplucker Read Only Funster
    Feb 14, 2011
    Plymouth
    Probably a silly point, but I had a Morris Oxford once and armed myself with replacement clutch to cure same problem. However, when I got underneath to remove gearbox bolts there were only 2 left and they were only hanging on by a couple of threads so depressing the clutch just moved the gearbox backwards!
    PP
  11. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    Wolly is quite right, any of these base vehicles need the pipe extended and thrown down the back.
    Just one question - is you speedo doing anything lately, like flickering needle? Only reason I ask is, the water ingress on these boxes can actually cause a bit of damage due to too much 'fluid' (water and oil) - It would be wise to use it as an excuse to drop the gearbox oil and change it after you have moved the pipe.
    If you out some in an old jar and leave for a few hours, you will see it seperate if water is present.
  12. lou020
    lou020 Funster
    Oct 5, 2010
    414
    257
    huddersfield
    probably your thrust bearing for the clutch,does the vehicle still try to drive forward (dragging) when you press clutch pedal down, in gear with engine running. try starting engine with clutch down in 1st gear. if it moves forward,
    then it must be a clutch problem.
  13. Squire
    Squire Read Only Funster
    Dec 30, 2010
    324
    60
    Hi pheasantplucker - completely off-topic so I hope you're going to be pleasant ! This weekend I plucked and dressed 2 brace of pheasant - shot on the last day of the season - and I find it a long, tedious and thoroughly distasteful job, not to mention messy. I've been doing it for the past thirty years and every time I've wished for someone like you. Are you a professional plucker then? You don't fancy doing some extra curriculum plucking do you? I wouldn’t mind watching … :Wink:
  14. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,102
    17,771
    YO11 2BD
    bit of a voyeur then are we :Rofl1:
  15. Squire
    Dec 30, 2010
    324
    60
    We? You too?
  16. pappajohn
    Aug 26, 2007
    30,102
    17,771
    YO11 2BD
    :Doh: walked into that one, didnt i :Laughing:
