Emmit
Over the winter when we were Sur la Continent, we came across what we judged to be a requirement for a rooflight in the Bathroom.
The cold mornings induced loads of condensation that didn't easily disperse by opening the rear window, (and I didn't think I'd get suitably favourable comments about my nether regions being visible either).
Decision made, unfortunately we can't get a Mini Heki in the roof as there isn't enough space to get 520 x 520mm which is the dimension.
I can get however the Fiamma Chrystal rooflight in as it's dimension is 430 x 430mm.
My only concern is that there are two Heki Specs. One with permanent ventilation and one without. It specifically says in the blurb that motorhomes should install the Heki Without the vent because in fitting the one WITH will result in noise coming from it when in motion.
The Fiamma apparently only comes WITH Perm. Vent.
We don't want to go down the route of an electric vent.
Question. Has anyone retro fitted the Fiamma? If so, does the unit create a Howl and if so, how intrusive is it.
