Advice pls (1 Viewer)
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
My van is a couple of years old and the Windows have started to leak, the manufacture has issued a recall to install new Windows, however the new ones look nothing like the originals and change the look of the van in a major way I have asked if they can be replaced like for like but they are unable/willing to do so
Do I have a leg to stand on if I want to question this with the manufacture as I feel I no longer have the van I purchased (the external appearance was a major factor in my decision) or am I p***ing in the wind
Thks for any advice
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
I'm not sure of your legal position here but it sounds a horrible situation to be in. Good luck and I hope you get some good advice.
Badknee
7,407
412,525
notloB
Vantage Neo
Living the dream.
Hmmmm, are the original Windows "standard" ones like fitted to many other makes? If they are just fitted by your company perhaps they weren't any good and need a new design fitting that will last?
Gorse Hill
Gorse Hill
2,364
1,944
Stretford
Yes originally fitted by the manufacture, they have a standard window which is covered in a black perspex curved along the side of the van (not seen it on any other van) these have not failed buckled/warped and are being removed which changes the whole look of the van
Will post some pictures, thks
maz
Jan 26, 2011
4,460
7,737
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Minxy
32,635
66,513
E Yorks
Carthago Compactline
I assume you currently have something like this:
Broken Link Removed
Minxy
32,635
66,513
E Yorks
Info about the new windows here:
Broken Link Removed
This is what they look like:
Minxy
32,635
66,513
E Yorks
I suppose you could refuse but then you'd have no comeback against Hobby. I remember seeing these Hobbys when they first came out and thought the 'slab' windows were more a style statement that a practical proposition.
Our previous Autocruise PVC had the type of 'standard' windows they are now putting in the Hobby where as our current Globecar PVC has the large 'slab' windows - I much preferred the 'standard' style in use.
Broken Link Removed
I just hope our large windows don't start to have problems!
Badknee
7,407
412,525
notloB
Vantage Neo
Living the dream.
No I didn't mean that really. Having seen the pictures now they may not be standard across a whole range of vans an might be "peculiar" to yours. If they have chosen wrong and they don't work I'm afraid changing them for some that do work and will continue for years to come may be the only answer?
Gorse Hill
Gorse Hill
2,364
1,944
Stretford
I I remember seeing these Hobbys when they first came out and thought the 'slab' windows were more a style statement that a practical proposition. !
Your not wrong there MG(y)
43,319
49,384
I guess it would depend how and where they originals are leaking.
If its the actual window that leaks rather than the fixing to the wall then why would you want the same crap designed windows fitting again.
As they insist changing to another make/design i would think its the actual window design at fault.
If it is just the wall to window seal then simply have them removed and resealed.
Minxy
32,635
66,513
E Yorks
I assume the size/material used for the window 'cosmetic' cover is what is causing the problem by warping over time and distorting the actual 'pane' that seals the window itself hence letting the water in. What would worry me if I insisted on keeping the originals is how long will they continue to distort ... would it get to the point where they were totally useless? Another thing that concerns me about these 'larger' cosmetic windows is that I believe they are easier to break into - this happened to us in Pisa when someone was able to yank our dinette window open and break the catches - if the window 'cover' hadn't been so large they'd have had less to grab hold of.
If you love the MH otherwise I think it's a case of accept the 'fix' and get on with enjoying it - annoying, yes, but if it means it is leak-free, usable and secure that's got to be the most important thing - after all you are usually sat inside looking out anyway!
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
Since 2010
I nearly bought one as I liked the flash look.
Meaning a flash along the vehicle.
Glad I changed my mind now on the drive home from nec
Gorse Hill
Gorse Hill
2,364
1,944
Stretford
It's both the cover and window that's leaking PJ, your right I do need to get them changed and I will, however to me it's not the same looking van with the new windows and as @Minxy Girl pointed out I am inside looking out but to me a significantly different looking van than the one I purchased hence my question does the manufacture have any responsibility to provide like for like
Peter Ashcroft
124
90
Wigan
Autoroller 600
Since 2014
I would be extremely unhappy and completely understand why you are, the new windows do not look anywhere near as good as the existing, as you say , it completely changes the look of the van, for the worse.
Peter Ashcroft
124
90
Wigan
Autoroller 600
Since 2014
Sorry Gorse Hill, on re reading my comment its probably not made you feel any better, that wasn't my intention, I was just agreeing with you that it has changed the look of the van, I do hope you manage to find a solution, its still a great looking van in my opinion.
Emmit
8,032
17,739
Cornwall
Pilote Explorateur
Jan.2014
First things first. Daft as it sounds, your beef is not with the manufacturer, even though he's the one that is providing you with a new set of windows. It's surely with the person you bought it from. ie the dealer
The problem you have is the 'van is two years old and I cannot see any Court allowing you to 'reject' the van and get your money back.
Therefore, and whilst I accept that the 'new' windows dramatically change the look of the 'van from sleek and stylish to 'I'll put the windows in as an afterthought,' I would suggest that your only recourse in Law would be to take the dealer to Court, claiming that the ascetic look of the 'van has changed so much, that you will lose money as and when the time comes to change.
Speaking purely as a layman but also as a Hobby lover, I can tell you that, prior to the problems with the windows, I would have wanted your prefacelift 'van in a heartbeat. I cannot say that with the 'new' windows fitted. I suppose what I am saying is that in my eyes, your 'vans old look was desirable. The new look isn't so and in my eyes at least, that will have an impact on your 'vans resale value and as consequence you should have recourse to Law.
Gorse Hill
Gorse Hill
2,364
1,944
Stretford
To be honest I am a bit gutted about it, we use the van nearly every weekend and will continue to use it I love the lifestyle just a bit p***ed off it doesn't look as nice with the new Windows
on the other hand am lucky having a new van so not the end of the world
Minxy
32,635
66,513
E Yorks
Has anyone noticed one of these in the 'cattle sheds'? As I walked by I saw that the windows on that one were warping ... not good! I hope the dealer gets them sorted BEFORE he sells it and tells the new owner about them!
Gorse Hill
Gorse Hill
2,364
1,944
Stretford
Been a recall from Hobby had mine done a couple of weeks ago, if not he/she not going to sell it
Minxy
32,635
66,513
E Yorks
We saw it today, it had been moved further back - it was at the front originally - as it had been sold! I doubt if the new owner noticed the window problem, unless you know about it you wouldn't realise or think to check.
How does your MH look now? Is it better than you thought?
Gorse Hill
Gorse Hill
2,364
1,944
Stretford
Looks a lot better than I thought it would MG
It's good but it's not Carling
Did you notice how much they wanted, selling mine within the next month
Thks (y)
Minxy
32,635
66,513
E Yorks
Sorry I didn't notice the price but if you have a Google its probably still for sale on their website as I doubt they'll have updated it yet ... can't remember which company it was though! :rolleyes:
