Advice please (2 Viewers)
movan
21,492
120,753
Moving around
Burstner
since07
In storage my van is parked under a tree and no way of cleaning it.
On a campsite today I paid someone to clean it and he said the roof was really really bad with green stufv ofc the trees .. in one sechion about 4" x 18" the paint had come away completely ..
I have phoned around to find someone to do the job but will still be under the tree.. :( .. If I don't have it repainted yet until I can find somewhere else several months down the line, what will happen to the area ... e.g. rust or nothing. A friend says mhs won't go rusty because of what they are made of. Ty.
Nov 6, 2013
3,201
229,472
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
What van have you got Joy?
If it's a PVC it could well rust but if it's a coach built it will probably be GRP with a gel coat covering which won't rust but may become a little porous if the gel coat has deteriorated. I'm sure you will get more expert advice later but I would try and find an alternative parking place ASAP.
43,329
49,444
If it's aluminium it won't rust but will developed a 'furry' appearance over time.
Like a coating of heavy grey/white dust which is the aluminium oxidizing.
The paint around the damaged area will also continue to come away.
Depending what the tree is you may also get tree sap dripping on the roof.....when it hardens its a Bugger to get off.
I would get it sorted asap to prevent further damage.
A top cover maybe a good investment but difficult to fit on your own as you need step ladders and the covers aren't lightweight.
Lorryman100
640
1,015
UK/Scotland
Rapido A class
Something like this would be a good investment if you cant move pitches in the storage yard. A little bit of forethought before fitting by re rolling the cover would enable you to use the attachment ropes to unroll it on the roof or even pull it onto the roof from the ground.
Protec do full covers that can be put on by one person as they supply poles to ease the cover over the van but are full covers and a tad expensive, though may be worth a call to see if they would make you a roof only cover.
http://pro-teccoversonline.co.uk/
Best option for now would be to get it away from under the trees. JMTW (y)
Baileysbus
731
2,414
Fife
Start of 2016
@movan
What you need is a good chainsaw ......... just saying :rolleyes:
Teuchter
Nov 4, 2014
1,404
4,001
Lee on the Solent
Hymer Mercedes MLI 580
I have been caravanning for 32 years but in 2014 I have"gone over to the dark side"
Here's my advice - not very clever etc. but what I would do in the same circumstances :)
Have the roof "plasticised" or "plastidipped" I believe there are one or two threads on here about the process.
When it comes time to sell the van - peel it off or leave it on - up to you (y)
Two on Tour
10,327
50,952
Elddis Autoquest 175
Since 2010
I have mixed feelings about covers on any vehicle parked outside for a long period. A couple of years ago we used a generic type cover on the last motorhome we had. It was a reasonable fit and good quality (Royal) but not tailored for a snug fit. We used it over winter to keep off general detritus and grot from a nearby tree, but because of the wind moving the cover over the winter period when we removed the cover we found that cover although with a soft inner it had polished corners and rubbed through paint in some areas.
