Advice please Flat engine battery
Discussion in 'Motorhome Chat' started by kaybee, Apr 6, 2016.
  1. kaybee
    kaybee Funster
    Apr 3, 2012
    382
    211
    Lincolnshire
    Hi Folks
    Had the motorhome on charge all day yesterday only to go out to it today and discover I have a flat engine battery. I mistakenly thought that the engine battery automatically charged up when I had it plugged in but it only charged the leisure batteries. I have now got it charging the engine battery only but I assume it will take a full day to charge. Question is can I start the engine whilst pluged into the mains or am I likely to blow the house electrics? Thank you
  2. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,593
    7,877
  3. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,508
    2,732
    Surrey
    As above, our van will not start when hooked up, alarm sounds and engine will not turn over.
  4. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,780
    6,048
    Mansfield,Notts
    Mine will(y) and it will let you drive off still plugged in:giggler:
    • Funny Funny x 4
    • Thanks Thanks x 1
  5. TheCaller
    TheCaller Funster
    Sep 23, 2013
    1,959
    2,333
    Lincs
    As a generality, I'd say it is always better not to try & start the engine while you have a mains charger in the process of charging that battery. At the very least, it's going to make the charger run at it's maximum output. Other than that, a decent charger shouldn't be damaged by doing so. I suppose an intelligent charger might be confused into thinking the battery was duff, but that would be fixed by turning the charger off & on again.
    There is a possibility of blowing a fuse or tripping a cut-out if you are unlucky. If it does blow the house electrics then it has shown up a more serious problem altogether!
    I'm assuming that you have a built in charger in the motorhome that you have to switch between charging the leisure batteries only or the starter battery only?
  6. Zepp
    Zepp Funster
    Jun 22, 2008
    751
    1,012
    Portugal For Now
    And mine :LOL:
  7. Peter & Elaine
    Peter & Elaine Funster
    Aug 30, 2012
    4,018
    6,543
    Roobarb land
    and me
  8. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,936
    12,190
    Plympton, Devon
    It shouldn't take all day to charge up enough to turn the engine over. A few hours should be enough but the battery works t be anywhere near fully charged so don't switch the engine off until you have driven for a few more hours.
    However, worth investigating why the engine battery is flat. It may be faulty.
  9. golly
    golly Funster
    Aug 16, 2009
    1,181
    2,126
    Co Durham
    Get one of these excellent bit of kit
