advice on gearboxs on motorhomes. (1 Viewer)
geo glasgow
292
274
Glasgow
Auto-trail cheyenne
OK 78k miles on my m/home.
gearbox lost 5th gear totaly at weekend
also 2-3 grinds and 4-5 did grind now 5th lost,
anyway striped out box today took over to tranmission recon in FACTORY IN glsgow to refactory,
#Advice free from these guys,
I asked is this normal and do u get a lot of m/
home gearboxs for repair.
he states yes more than vans or trucks in proportion to how many motorhomes are on the road?
problem is that motorhomes can sit for weeks at a time that being that the oil sits dormant in bottom of box this can start to stiffin up all or most parts on the gears when we go to use the box when driving 5th gear especialy gets used less and only gets a small part of oil dispersed from other gears this can cause bearings and small parts to dry or seize,
once serviced and repaired always top up with semi synthetic oil every 15-20k change completly never allow to stand for more than 2-3 weeks never more . if this is the case always warm up engine and move carfully round all gears incl 5th . the shame is from his mouth is some motorhomes get used less that 2k a year meaning thats a lot of standing time,, make sure water cant sit on or around gearbox and seals are bolts are checked with services, top gear oil and condition as often as possible, oil is cheep and i can tell you a gearbox refurb and time is not..
:thumb::thumb::thumb:
flatpackchicken
1,277
1,757
BICESTER OXFORDSHIRE
A Class Frankia I8000
Since nov 2009
Hi, May be Talking boll***s here, but I understood that fiat's suffer with 5th gear failure or jumping out of 5th gear and can be replaced by removing cover from near the N/side front wheel, but as other gears grinding then synchromesh gone by sounds of it so need box right out to fix. Regards Garry Flatpackchicken
Snowbird
11,818
22,345
Liverpool.
Fifth wheel.
Since 11-05-2000
No Garry, you are not talking boll***s :thumb:
DBK
18,009
48,001
Plympton, Devon
PVC, Murvi Morocco
A factor between vans and motorhomes is the latter are more or less run close to GVW all the time. This must mean MH gearboxes are more highly stressed.
I am not sure how lack of use could shorten a transmission's life. Easy to understand how this happens on an engine (corrosion) but a sealed gearbox?
Depending on the year the 5th gear problem is well known and if left 'untreated' other problems will manifest.
