Advice/help needed on motorbike rack van/weight
Discussion in 'The Beginner' started by Rangersmith, Feb 7, 2016.
  1. Rangersmith
    Rangersmith Read Only Funster
    Feb 5, 2015
    10
    wales
  2. Derbyshire wanderer
    Derbyshire wanderer Funster Life Member
    Mar 30, 2014
    511
    867
    Derbyshire
    It depends on what your towbar is rated at. The bike and rack will be about 210kg which is a lot. Which Bolero are you getting?
    My 724FB has a Towtall bar rated at 150kg which I used to put a Gilera 200 (129kg) on an Eastlifter standard rack (30kg) total 159kg ( yes slightly overloading the towbar but it is built to take double the rated load). This added about 250kg to the rear axle load due to the overhang but well within the 970kg payload and left another 80kg axle weight even with a full water tank.
    The reason I use a trailer now ( and my 1150GS) is that the rack was technically too long for a fixed overhang by 120mm as the maximum allowed is 60% of the wheelbase.
    • Informative Informative x 1
  3. Badknee
    Badknee Funster
    Aug 25, 2014
    3,790
    16,826
    notloB
    the load put on your rear axle that will bugger you up. There is a maximum weight including all your gear then you have to take in the fulcrum effect caused by the distance from the rear axle to your bike and rack and it's pretty big. If you notice the rack in the advert the rack is quite close to the axle of the Volvo so the fulcrum effect will be much less.
  4. hilldweller
    Dec 5, 2008
    27,558
    26,669
    Macclesfield
    We need two measurements: Wheelbase, distance from rear wheel centre to centre of bike, a good estimate will do.
    The you need to get to a weighbridge and get the two axle weights, don't trust anything in the book.
    After that it will be "bollooooooooooooox" or "yippppeeeeeeeeeeeeeee".
  5. Rangersmith
    Feb 5, 2015
    10
    wales
    Thanks for quick reply's
    I have not got MH yet so I have yet to put tow bar on, the MH is a bolero 680 fb sorry forgot to mention that
  6. hilldweller
    Dec 5, 2008
    27,558
    26,669
    Macclesfield
    Get the weights and do the sums first, just in case.
  7. Rangersmith
    Feb 5, 2015
    10
    wales
  8. hilldweller
    Dec 5, 2008
    27,558
    26,669
    Macclesfield
    Do a search on this forum, I'm sure there were negative comments some time in the past. I may be wrong.
    The really neat way to avoid weight problems is one of those ( French ? ) close coupled trailers with castering wheels. Then again I recall a UK version that was a disaster. This solution is expensive.
  9. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,926
    1,944
    Warwickshire
    As Brian has said, you need to get all the actual weights and dimensions, including the actual axle weights. According the the brochure in your first post, the 680fb has only 450kg payload to start with. If you add probably 250kg or more at the back, there will be very little left for any other gear inside. Unless the van has been updated of course from the standard 3,500 kg GVW.
    • Like it Like it x 2
  10. teensvan99
    teensvan99 Funster
    May 17, 2015
    226
    246
    Margate
    Do what we did. Bike rack on back and carry a little 125. We have gone away from trailer with 650 Suzuki. We have found the 125 is fine for round trips of upto 30 miles or shopping with 40ltr back box. Wife is now 68 so we don't go as far as we used to.
  11. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    10,492
    11,851
    E Yorks
    You don't want to hear this but you are buying the wrong MH if you want to carry a bike on the back on a rack! The only way you'll be able to take it is to put it on a trailer of some sort .. sorry.
    • Like it Like it x 1
  12. Derbyshire wanderer
    Mar 30, 2014
    511
    867
    Derbyshire
    At 3500kg gross with a payload of 450kg the rear axle will defiantly be well overloaded.
    Very true, this is your only legal option really as even with a much lighter bike, the payload is not enough.
  13. Rangersmith
    Feb 5, 2015
    10
    wales
    What about this option -
    http://www.easylifter.co.uk/hydra-trail.htm
  14. Minxy Girl
    Aug 22, 2007
    10,492
    11,851
    E Yorks
    Yes that should work so long as there's enough spare capacity for the downwards weight of the coupling/bike on the towbar, but won't be anything like that for just carrying the weight completely on the back as per just a rack.
  15. Rangersmith
    Feb 5, 2015
    10
    wales
    This trailer is fixed to the van using an adaptor plate.
  16. Minxy Girl
    Aug 22, 2007
    10,492
    11,851
    E Yorks
    However it is attached the point I was making is that the weight it places on the back will need to be taken into account for the rear axle loading.
