Advice from comfort insurance blog (1 Viewer)
glastry
395
356
northern ireland and portugal
a class s550
Some interesting advice, "always let your battery's run flat,before recharging,or you will shorten your battery life?"
Have I missed something?
(Under the heading - summer sun and solar panels,about the fifth paragraph?)
I should also say that this is an insurance company, that i rate highly.
mikebeaches
5,346
8,469
Bristol
Rapido V68 Van Conversion
Since 2009
Bizarre - I think that's lithium batteries and the memory effect, not lead acid or gel. Sounds a recipe for wrecking them. (n) :(
Aug 6, 2013
11,941
16,534
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Not even lithium - it was NiCad in particular and to some extent NiMH. Li-ion unaffected.
Feb 27, 2011
14,671
74,888
UK
Self Build
Tony is correct. If you let a Li Ion or Lead acid discharge too much you will damage them and shorten their useful life. Nicads had what is called the memory effect and did need to be discharged to maintain their capacity. Do NOT do this with lead or Lithium batteries.
