Adria Coral Electric Wiring (1 Viewer)
Beachedbuoy
8
5
Conwy
Low Profile
Does anyone know where the electric supply, for the ignition, to the Gas Hob and Oven originates and is it fused ?
Both have gone dead so I assume they have a common source, they are not wired from the Electroblock hence the query. Adria dealers seem unable to help. The vehicle is a 2007 Ducato
Any advice would be welcome also if anyone knows where I can get a wiring diagram.
Thanks.
lunarman
2,156
2,451
South Glos
since 1994
Are you sure its not a 9v pp3 battery hidden in the back of one of the cupboards by the oven.
Lunarman
B
Beachedbuoy
8
5
Conwy
Low Profile
Thanks for the suggestion, not seen anything so far, will have to investigate.
Regards:Smile:
B
Beachedbuoy
8
5
Conwy
Low Profile
Adria Coral Wiring
Hi Lunarman::bigsmile:
Had a good look in all the accessible places but no battery pack.
The wiring from both appliances goes into a flexible conduit and then disappears under the floor.
Short of attacking it with a chain saw I will have to stick with a box of matches for the time being.
Thanks anyway.
regards
Pete:Smile:
TheBig1
17,604
43,079
ive seen a few vans with a hidden leisure side fusebox, under a flap in the floor directly behind the drivers seat. Not familiar with the adria wiring specifics though
If you took the van to an auto electrician, they would use a cable tracer that puts a signal down the wire which can be followed then with a detector. As a general rule this will head towards the leisure battery, as the fuses will normally be nearby, either in a locker or under a seat or even in a floor compartment
B
Beachedbuoy
8
5
Conwy
Low Profile
Thanks for your suggestion, it will probably come to getting a Sparks to sort it.
My Coral has a box of tricks called an Electroblock which is a combined Battery Charger and 12v Fused Distribution, fitted near the Leisure Battery, serving the Habitation Area, but nothing on it for the Cooker and Hob.
I've attached a wiring diagram in case your having trouble sleeping.
Regards
Pete
:Smile:
