adjustment knob on hymer arm rest (1 Viewer)
lebesset
760
as the zip on an armrest on my 584 has parted I wish to remove the cover to repair it
question is , how do you remove the adjustment knob to slide off the plastic cap ?
anyone done this ?
43,321
49,408
sorry, not sure how they are fixed but have a look around the knob for a small grub screw.
failing that it may just be a tight push fit onto splines and will just lever off.
L
lebesset
760
well as you can see my enquiry didn't really get an answer ; I have tried getting at the grubscrews by pulling the knob off the splines , but it won't budge ...in any case the knob has to come off to get the plastic cap off , as far as I can see
any recent joiners know the answer to this one ?
Jan 27, 2009
872
3,359
Leyland Lancs
since 2001
Contact Regal Furnishings Ltd, 01159-326451 They will know, and I have always found them helpful in the past!
39
3
dundee
a class
since early 70s
Adjustment knob should just pull off as it is just pushed on to splines on rod. Dont try removing rod as it is not easy to get back in place as retaining nut will fall out. Bob
L
lebesset
760
thanks bobcat ...that sounds like the voice of experience ...have you actually pulled the knob off yourself ?
L
lebesset
760
well , I tried and I tried , but can I pull this knob off the splines ?
it certainly has been just been pushed onto the splines , there are no screws holding it on
,maybe mr hymer puts some adhesive in !
any ideas anyone ? knowing what new bits cost I have resisted the hammer and chisel approach so far :Sad:
Sep 27, 2007
39
3
dundee
a class
since early 70s
adjustment knob on hymer armrest
yes i found out the hard way.i kept unscrewing the adjustment untill the rod came out.Unfortunately the retaining nut fell out of place and i had to strip it downto replace it.
L
lebesset
760
does that mean you never did get it off the splines bobcat :Doh:
